996.1 vs. 996.2 suspension
The 996.1 had two basic chassis the C2 & C4... then the 996.2 used the C4 chassis on all models for improved strength. The reason you see a M030 for both is they made the 996.2 springs a little bit stiffer. That will not effect your usage at all. The mounting points and everything else is the same.
