996 Forum 1999-2005
X74 Sway Bar Question
Old 02-12-2011, 03:46 AM
reynwerkes
reynwerkes's Avatar
Default X74 Sway Bar Question
I installed an X74 kit on my 02 C2 without sway bars.
Now I have an opportunity to buy a set for a fair price.
However, I was wondering if anyone had any feedback on the X74 sway bars compare to the stock bars. Do they make much of a difference for street driving?
My car won't be used on the track but I do enjoy taking the car out for agressive driving when the roads are clear.
Thanks!
Old 02-12-2011, 09:53 AM
Sneaky Pete
Sneaky Pete's Avatar
The X74 bars are the ROW M030 bars. The X74 provides shorter / stiffer struts. The thicker sways give you flatter cornering when combined with the X74 struts. I'd put them, you will have a complete kit.
Old 02-12-2011, 07:26 PM
sparks259
sparks259's Avatar
get the gt-3 sways.
you won't be sorry.
i've got them on mine.
Old 02-13-2011, 09:19 PM
smackboy1
smackboy1's Avatar
If you can find it there was a PCA article "996 Standard and Sport Suspensions Analysed" by Russ Dickerson, Bob Gagnon, and Mike Schatz, that is a good read. I can't find it online anymore.
996 factory stabilizer bar information from the article:
US Std Front: 23.1 mm dia., 3.4 mm wall thickness
Sport Front: 23.6 mm dia, 3.5 mm wall thickness (9.58% stiffer than std)
US Std Rear: 18.5 mm dia, 2.5 mm wall thickness
Sport Rear: 19.6 mm dia, 2.6 mm wall thickness (24.15% stiffer than std)
The Sport Stabilizer bar is the same for RoW M030, US M030 and X74.
I've never experienced a car with X74 struts + Std Stabilizer bars so I can't comment, but if the car is never on the track/autocross I'm wondering if the added stiffness will make much difference on the street. In fact wouldn't the increased amount of roll and softness of the Std setup help in the rain and snow when you want more weight transferred to the loaded tires?
Old 02-13-2011, 11:36 PM
redridge
redridge's Avatar
now.... can anyone explain those re-enforcement brackets that mounts on the brake light area. WTF is all that about?
Quick Reply: X74 Sway Bar Question
