Retrofitting PSE to 996
I really appreciate how quiet / comfortable my C2 can be on long drive but I wanted extra grunt for my joy rides. I was considering having a PSE installed with the switch & harness, but if it comes up to 6k$ I'll have to skip my turn.
I was ready to spend some extra over an after-market set, but not 6k$.
Registered User
I don't think it is anywhere near 6k if you have the mufflers. I just bought the hose fittings and valve for less than $150. The harness is around $250 from Pelican and the switch is around $30. The total job should be doable in less than 2 hours. Plus you will need to get the dealer to activate the PSE mode if that is the route you go.
I am just going to wire an on-off switch to the crossover valve (vacuum valve).
Langg
Langg
Langg
Langg
