996 Forum 1999-2005
Day two of ownership and I already need help
Old 02-05-2011, 12:37 PM
redridge
redridge's Avatar
I've had these codes.... Replaced the cats, codes never came back. I would go with 200 cell racing cats since you car is SC... The high heat will kill oem cats in no time. But if it is under warranty... Then go for and then sell it.
Old 02-05-2011, 12:40 PM
rpm's S2
rpm's S2's Avatar
That is a pretty expensive suggestion. I would troubleshoot myself and then have a good shop troubleshoot before replacing cats.
Old 02-05-2011, 12:49 PM
redridge
redridge's Avatar
No doubt it's expensive.... But most likely it is not vac related or any of the above mentioned.... Just cutting to the chase... My car is SC and has been through this before like many SC owners. Though I have seen dealers replace cats under warranty even if it is SC modded....
But I've been wrong before...
Old 02-05-2011, 02:25 PM
Toomanycars
Toomanycars's Avatar
I'm going to replace the cats regardless since the rattling they make is enough to drive a person nuts. I was thinking of going with the bypass pipes. Anyone here have luck with them and not getting a CEL when used with the 02 adapters?
Old 02-05-2011, 02:39 PM
fpb111
fpb111's Avatar
Ferd,
I remember that time you were wrong, it was when you thought you were but weren't.
Old 02-05-2011, 02:44 PM
Macster
Macster's Avatar
Originally Posted by Toomanycars
Thanks I read all the threads I could find on it just not sure if they are related to the loose rattling cat. The car hasn't been driven for almost two years so it's bound to have a few issues. I will check this stuff tonight when I get home.
Not being driven for nearly two years can cause all sorts of problems. I came across a Porsche (993 Turbo S) the other day that had not been driven for a bit longer than that and the tech told me he had to replace the fuel pump (it had seized), new fuel lines, and injectors, among other things.
Plus a car that sits unused that long can attract the rodents and they love to gnaw on things plastic and rubber.
I'd give the car a thorough inspection looking for any rodent sign. If you find any then you have to suspect the engine hoses, wiring harness have been chewed on. In some cases the engine has to come of the car to access/replace all the damaged hoses/wiring harness.
Sincerely,
Macster.
Old 02-05-2011, 02:47 PM
ivangene
Parts Specialist
ivangene's Avatar
Originally Posted by fpb111
Ferd,
I remember that time too - it was almost as funny as the time I thought I was right......
but wasnt
Old 02-05-2011, 03:05 PM
Toomanycars
Sincerely,
Macster.
I shouldn't have said not driven but driven very little. About 1000 miles in the last two years. It was in a garage as well. I'm not too worried about it I know its something simple just getting to it will be my main problem.
Old 02-05-2011, 05:35 PM
FLY996
FLY996's Avatar
May want to look at the new FVD X-Pipe Cat designs...(Happy camper here with the 200 Cell...no CEL)
Bypass
100 or 200 Cell
Old 02-05-2011, 07:00 PM
Toomanycars
Ok guys upon further inspection I found a broken Vacuum line that goes to what I believe is the electronic change over valve. Unfortunately it broke the nipple of the valve and it's behind the supercharger and I have no clue how to remove the supercharger. Im going to plug the vacuum line going to the intake for now so I'm not running lean.
If anyone has a write up on the supercharger removal that would be great!
Fly 996 are you saying you have no CEL with the bypass or with the 200 cats?
Old 02-05-2011, 08:56 PM
C4CRNA
C4CRNA's Avatar
I had a bunch of O2 sensor codes and it was really the MAF.
Do you have the KN Oiled air filter?
Old 02-05-2011, 09:00 PM
Toomanycars
Yes it has a oiled K&N I'm going to pull the MAF and clean it but I found yet another broken vacuum line going to the boost bypass valve so I fixed that one easily. The car idles a million times better now with the vacuum leaks plugged. Now I just need to order the electric changeover valve and I think it will be all back to normal sans the rattling cat.
Old 02-05-2011, 09:22 PM
FLY996
FLY996's Avatar
I'm running the 200 Cell X-Pipe...no CEL
Old 02-05-2011, 09:41 PM
Barn996
Barn996's Avatar
Way to go, sounds like you have solved most of your issues.
Old 02-05-2011, 11:15 PM
Pac996
Pac996's Avatar
Solved them all unless he has to move to california with smog checks
Quick Reply: Day two of ownership and I already need help
