rear strut top access on cabriolet
How do you gain access to the 3 strut top nuts on a mkII cabriolet? Can I just remove the panel behind the seat backs or can I only gain access with the roof partially open? Thank you.
just partially open the top then release the two hook (actually like a wire) then lift the rear window. when the rear window is up, you have access to the strut top after you dig under the insulations. Good Luck!
