Steering wheel creaks in the cold - is there a fix?
that is a good video of the removal procedure... IF you take the steering wheel off to re-align its position ~after replacing the clock spring... Just keep in mind that the clock spring will have 2 tabs on it that WILL brake off if you pull hard on them... You want to compress the spring clips before you yank off the steering wheel.
