996 Forum 1999-2005
Drive shaft removal
Old Nov 27, 2010 | 11:45 AM
JeffC's Avatar
JeffC
Default Drive shaft removal
I need to disconnect the drive shafts from the transmission (2 wheel drive) to remove the tranny and replace the clutch. My question is what size tool is needed for the drive shaft bolts? I searched and found instructions but none seem to mention the size of the bolt head. The tool I had for my 944t doesn't fit.
Jeff
new owner of '99 996 w/130K miles
Old Nov 27, 2010 | 01:42 PM
OZ951's Avatar
OZ951
M8 Allen head bolts on my 99 C2
Old Nov 27, 2010 | 06:26 PM
Dharn55's Avatar
Dharn55
I forget the exact size, it may be an 8mm, but it is a hex head/allen wrench driver. One trick to make it easier to get at them and get them out is to remove the rear wheels and use a 24" extension to reach them through the wheel wells, much easier than working from underneath and working around the driveshafts.
Old Nov 28, 2010 | 11:03 AM
JeffC's Avatar
JeffC
Thanks for the info. The rear wheels are already off and the car is on jack stands. Great idea.
Jeff
