Getting ready for Winter Storage...
Hey everybody! The weather is starting to change and its about time for the Porsche to stay in the garage. I play on letting it sit until April 2011. I have read a few threads regarding storage already. What do you all recommend since it is my first winter with the car. I was thinking:
-Change oil
-Clean interior
-Fuel Stabilizer
-Wax and Cover
-Disconnect battery
Am I missing anything else???
-Change oil
-Clean interior
-Fuel Stabilizer
-Wax and Cover
-Disconnect battery
Ive used this for 4 winters.... no issues. Just clip on and forget it. I used its "O" connector to mount on the Batt terminals and just plug it on the tender for easy on/off attachment.
http://www.batterymart.com/p-battery...y-charger.html
![](http://www.batterymart.com/images/products/full/DEL-021-0150-DL.jpg)
http://www.suncoastparts.com/product...Code=POTE996WW
I picked up this one, will be giving it a try this winter.
Kinda silly.... but you get the idea, I heard a piece of carpet would help as well.
http://www.griotsgarage.com/product/...FQ915QodjW8o3A
Ryan:
Not sure what you get for moisture (humidity) once the weather gets warmer, but before you start driving. I hang a "damp rid" off the steering wheel adjuster, this will absord any moisture and prevent mold. Also, the mice love the cornstarch in the colored German wires, so I place mouse traps and Bounce dryer sheets, on the wheels, in the front radiator areas, in the tail pipes, under the car in the air intake areas, etc. Done this for 5 years and no problems yet. BTW: the Porsche trickle charger (a bit pricey) works great, simple plug it in to the outlet and the cigarette lighter...Oh yeah, put some gasoline stabilizer in and run it through the fuel system before you shut her down. Lastly, I put my baby away with a fresh oil change.
r\
Scott
r\
Scott
disconnect your battery but make sure to leave your hood open.... if you disconnect the battery and close your hood you may not be able to pop it open again.... I usually just put an old wrench in the locking mechanism so it cannot lock accidentally....
From what I have read, DO NOT PUT YOUR CAR AWAY ON JACKS. It is not good to leave the suspension unsprung for that 4 or 5 months period of time. It may keep the tires from flat spotting, but you can resolve that situation much easier by just overinflating the tires. Don't pull the emergency brake, just put blocks on both sides of one tire. That will keep the car from rolling. Then, every week or so, you can easily just push the car forward and back a foot, and that will keep the tires from getting flat in a spot.
In any case, if they do get flat spotted, for whatever reason, it will generally smooth out after driving it around in the spring for a couple of hours.
larry
larry
Ryan:
r\
Scott
r\
Scott
I thought a trickle charger was the way to go?
