Will these fit my 996?
on narrow body car with:
stock offset:
50 in the front
65 in the rear
but it seems you can push it up to ( TO BE VERIFIED by Ed![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
48 in the front
52 in the rear
Again, the smaller the number, the more the wheels will stick out of the fender.
stock offset:
50 in the front
65 in the rear
48 in the front
52 in the rear
So, along comes someone else with 4 mounted snow tires on aftermarket wheels that I saw on Tire Rack. I don't know if these are the same or just similar wheels to the ones that they spec'ed for my 996. These wheels are off of a Boxster. Can you confirm or deny whether these will fit my 996?
Front
17" (17x7.5)
Offset: 52mm
Backspacing: 6.29"
Bolt Pattern: 5-130
Tire Size: 205/50-R17
Rim Brand: Sport Edition Cup 4 (you can find these on Tirerack.com)
Tire Brand: Pirelli 240 Snowsport
Rear
17" (17x9)
Offset: 47mm
Backspacing:6.85"
Bolt Pattern:5-130
What do you think? It will be a good deal if it works. I am concerned about the Offset, and I don't have any clue of what the "backspacing" means. These will be shipped to me from CT.
larry
Front
17" (17x7.5)
Offset: 52mm
Backspacing: 6.29"
Bolt Pattern: 5-130
Rear
17" (17x9)
Offset: 47mm
Backspacing:6.85"
Bolt Pattern:5-130
larry
