AOS replacement and pad change out.
#61
I am having issues with being able to tighten the driver side manifold bolt closest to the aos. I managed to get it in the hole, but i can't get a socket on it now to tighten it. It's almost as if the aos isn't completely straight, but things were tight when i had installed it.
I would assume that i need to remove the manifold and aos again and see if that helps.
