use this stuff.. but a little is fine. You dont have to and if they make noise you can always add it later - you apply it on the contact areas... smells great when it gets hot
I use the same one.
But for the C4S, I took out the shims since the Pagids won't fit with the shims on.
Street pads without the shims have a slight faint of squeak, but nothing compared to Pagid squeaks.
