fs-Winter tires and Wheels
For sale-four Porsche 996 twist wheels-aftermarket twist wheels-7's and 9's-with like new Vredestein Winter Trac extreme winter tires. Tires measure at 9/32 and 10/32's. Best winter tire ever tested in Europe. Better than Blizzaks-$900. pcastator@gmail.com-The wheels are 17 inch
Pics on request
Pics on request
I AM SELLING FOUR 17 INCH PORSCHE AFTERMARKET WHEELS. THEY ARE 7X17 AND 8X17. I PUT THEM ON MY 2003 PORSCHE 996 LAST WINTER. THEY WERE DRIVEN A TOTAL OF ABOUT THREE THOUSAND MILES. I PUT THESE VREDESTEIN TIRES ON NEW LAST OCTOBER. THESE ARE RATED THE BEST WINTER TIRES IN ALL OF EUROPE. I HAVE INCLUDED SOME OF THE DETAILS. FOR MORE ONFO GO TO WWW.VREDESTEIN.COM. NEW TIRES HAVE A TREAD DEPTH MEASUREMENT OF 11/32TH'S OF AN INCH. THE FRONTS CURRENTLY MEASURE AT 10/32TH'S AND THE REARS MEASURE AT 9/32TH'S. THE SIZES ARE 205/50/17 AND 255/40/17. THEY ARE UNBELIEVABLE IN WINTER CONDITIONS-I LIVE IN WISCON SIN. THE TIRES WILL BE SHIPPED AT COST SHOULD YOU DECIDE TO PURCHASE. YOUR
STOCK WHEEL BOLTS WORK PERFECT.
DRIVE THAT PORSCHE ALL YEAR LONG THANKS TO TIRES LIKE THESE-READY TO BOLT ON.
The Wintrac xtreme is the first winter tyre to be developed in partnership with Giugiaro Design. Aggressive, firm lines give the W-shaped tread its powerful appeal. Sipe technology was a priority for Vredestein in the design of the Wintrac xtreme. Optimum Silica ProcessingTM (OSPTM) technology is incorporated in the fabrication of the tread compound, enhancing the winter performance and improving grip on wet surfaces. In addition, the equal distribution of pressure across the contact area ensures an even wear pattern, and low noise levels throughout the life-span of the tyre.
Features Benefits Features Benefits
Tread design by Giugiaro, in which the tread is integrated into the sidewall design
Advanced polymer-to-filler ratio in the tread compound
Double rayon carcass layer and extra robust belt construction
Non-directional, asymmetrical tread
Sophisticated Sipe Design: Advanced sipe composition
Enhanced appearance for sports cars
Optimal grip, even below 7°C Adequate stability, even at higher temperatures
High load-bearing capacity and good stability
Safe steering performance on both snowy and frozen roads
More traction and grip Excellent handling on bends
Developed by Giugiaro Design Innovative sipe technology
Optimum Silica ProcessingTM (OSPTM) in the tread compound
Speed ratings H, V and W
Equal distribution of pressure across the footprint
Powerful appearance due to aggressive, firm lines
Straight sipes across the tread for a good grip on snow Zigzag sipes in the tread shoulders for perfect handling
Increased grip on wet surfaces Excellent aquaplaning stability Good performance on snow and ice
True high performance winter tyre with good course stability and steering precision
Low noise levels throughout the tyre’s life-span Perfect driving performance in winter conditions
Parts Specialist
