Plumbing an Accusump
Hello,
I own a 996 that I have been tracking the last couple of year's. I have the similiar problem that other's have in that my oil pressure drops down to ONE bar in some of the heavier turns and braking conditions. It is just momemtary and not very noticeable unless you are watching the oil pressure gauge intently.
I put in the LN deep sump with baffle's and use Castrol Syntec 5/50. But to no avail. I have not modified the suspension and I am running street tires. I did install the LN IMS bearing, btw.
Next step is to add and accusump. I was wondering if anyone had suggestions as to where to locate it. And any anomolies in plumbing it. I would like to mount it under the car possibly in the tunnel if there is room.
Also Charles at LN rec's the manual switch, since my auto is a street car I think I would favor a cleaner installation with the electronic switch. Unless someone has a nice clean place to mount the mechanical on/off switch.
Thanks,
Mike
Thanks,
Mike
I mounted mine on the rear deck, but the interior has been stripped. I use a lever to activate. The local spec boxster guys developed a fitting for the oil filter housing, the filter is now located in the rear fender using a generic corvette filter (M1-107). The only other accusump in a 996 that I have seen was located in the passenger seat floor, also in a race car.
Pretty cool looking car. I like that you re-routed the oil filter. The set-up I was eyeing will use a smaller (10hr) oil filter. Trade-off between re-routing the oil filter and a smaller filter. Does the accusump activate much on the track?
I have a manual lever, which I open while the car is running. I am not familiar with the electronic switch set up.
Having trouble posting pics here so I will email and then maybe you can post them here. Check your email ...
Hello,
Thanks,
Mike
Thanks,
Mike
at what press does the system start squirting into the engine? how low of a pressure do you need to get to to active the mechanism...
does it also collect it when oil pressure is back up?
Can be adjusted.
Yes, recharges as press. goes up. With mechanical before turning off you can idle up the pressure then shut valve and shut off allowing restart to have pressure right away.
We just did this at work on a Cayman in the tunnel and it turned out really nice. We are going to start making full kits for all the different models soon. If you track a M/96/7 engine this is a really good idea.
If you wire a switch to the pressure valve, there's no need for a manual valve. Simply rev the engine to build oil pressure in the A-sump, then swicth off the pressure valve and it'll hold it. Some people just use a circuit that's only hot when the ignition is on, but at idle, the oil pressure could be below 35psi, thus draining the A-sump. If you turn off the key, you lose the ability to prime the engine on startup unless you turned off the engine while revving it, which doesn't sound like a good practice. I located the Accusump switch right next to the ignition key.
js
