996 Forum 1999-2005
no fuel or spark after engine replacment.
Old Sep 20, 2010 | 11:18 AM
hot-J's Avatar
hot-J
Default no fuel or spark after engine replacment.
The block was replaced due to a cracked.cylinder block now i get no spark or fuel. Could the immobolizer cause this? How would i test the system for proper function?
Old Sep 20, 2010 | 11:35 AM
nick49's Avatar
nick49
crank it a few times, then put your nose to the tail pipe. Pull a plug wire/coil pack, hook it up to a spare plug and ground it, have an assistant crank the motor, while you look for spark.
Old Sep 20, 2010 | 11:48 AM
hot-J's Avatar
hot-J
Sorry, i meant check the immobilizer system.
Old Sep 20, 2010 | 11:51 AM
Ubermensch's Avatar
Ubermensch
I believe the PSM is the only way to check the immobolizer system. It's more likely that you missed a ground strap somewhere. Take a look through all your electrical connections and confirm that the ground points are all clean and secure.
Old Sep 20, 2010 | 12:17 PM
hot-J's Avatar
hot-J
I just did a search and found a thread where the pulse sensor was bad? What is the difference between this and a crank sensor?
Old Sep 20, 2010 | 01:00 PM
hot-J's Avatar
hot-J
anyone have a lead on where to buy a 3.4 engine computer let me know....... i think this one is fried.
