Various part number help
So I am preparing to change the IMS bearing, I will take the engine out to do this job and to address many while at it items.
So IMS bearing, Oil/air separator, and timing chain guides
Can someone please list a list of part number of the parts I need to change out the timing chain pads?
To change the pads on the advance mechanisms you will have to remove the cam covers and pull off the cams. Requires two or three special tools. This is not necessary to replace the IMS bearing. You might want to consider replacing the chain tensioners if you are doing the bearing upgrade. This is covered on the LN website and is recommended.
