LED tail lights from Amazon
#46
ok I managed to debug my fuse problem.
At first I was quick to blame it to a faulty unit but after testing different configuration I realized that the unit was working, so I removed the left tail light, mind you only the right fuse was blowing up.
And then I realized that yet again, one of the little tongue within the wiring harness socket had broken and was creating a short ! man those things are really fragile. "lucky" for me it's only the rear fog light, which is useless to me.
I'll fix it later as I have another wiring harness, the one I broke a socket on last time I tried to install the led lights !
Anyways, all is good, everything works and look great.
Now two questions to you out there:
1- are both of your tail light 'rear/white' bulb light up when you put reverse ?
2- are both of your tail light 'fog light' light up when you pull the light switch 2 notch ?
For me even before the install I only had the rear right 'white bulb' working and only the rear left 'fog light' working. but while I am on the issue, I want to make sure I got it all working as ti should.
Picture 1: broken tongue in the fogl light socket that was causing the short
Picture 2: only one tail light have the rear coming on, even though I have a 'rear bulb' on each side.
#47
Phil, you know not to plug in the little corner lights right? the ones with a flat bulb..just dont plug them, shove them back into the LED thing without plugging them..if you do the fuse will blow
#48
Hum... I did plug those and they work just fine on my car. did you have any problem with those ?
You might want to check the rest of your bulbs for a short somewhere because for me they didn't cause any problem.
#51
Damn.... These would sell like hot cakes if the manufacturer would just make this a truly plug and play..... The reviews would be great and the demand would increase. Really to bad...
#53
I agree,
I really like the look, but everything about the product, from the shipping to the quality/ fitment/ design of the product seems to be bad. So, I will not be buying a set.
#54
I thought it was over but noooo....
So I made all my testing by turning ON and OFF the light switch and all was fine..
But now that I test it with the ignition key in and ready to start (or if the engine is running), my third stop light is turning on ....
Note1: that I have a LED third brake light kit installed, so I wonder if that picks up some low power that is usually in the system but not enough to lit up the blb version or... if I have another short somewhere
Note2: the picture is taken with the lgiht switch on, and the key in the on position. But I do NOT have my foot on the brake pedal.. I am taking the picture
Arghhh
help
Arghhh
help
