996 Forum 1999-2005
Another AC issue
Old Aug 30, 2010 | 06:31 PM
Nikedog's Avatar
Nikedog
Default Another AC issue
The AC on my 99 C2 when at speed works fine and blows cold. I have noticed the last two days when at idle the cold goes away. Any suggestions before I take it my indy?
Old Aug 30, 2010 | 07:25 PM
Van's Avatar
Van
Are your radiator fans working? Maybe they're not moving air over the condensers when you're stationary.
Old Aug 30, 2010 | 07:56 PM
Nikedog's Avatar
Nikedog
I am not sure. I will go check.
Old Aug 30, 2010 | 08:15 PM
Nikedog's Avatar
Nikedog
had the car idling with ac on. Radiator fans should be running with AC on. I hear a faint whirring. Can't tell if that is the fans. I checked the fuses. They were ok. Took the fuses out and started car with AC on. Still heard the same whirring. Not sure if the radiator fans are working.
Old Aug 30, 2010 | 09:52 PM
Dharn55's Avatar
Dharn55
The radiator/condenser fan are quite loud. If they are running you can't miss it. This is probably your problem.
Old Aug 30, 2010 | 10:29 PM
Van's Avatar
Van
Put your hand under the car in front of the front wheels. If your hand feels a lot of wind, the fans are running.
Old Aug 31, 2010 | 07:34 AM
Pac996's Avatar
Pac996
Typical of low on freon. Oops 134a
