996 Forum 1999-2005
Ebay Bypass Pipes
Old 08-30-2010 | 08:25 PM
RPMulli's Avatar
RPMulli
Here are the adjusted pics... it actually turned out well after i tweaked it when i got home..
Old 08-30-2010 | 08:53 PM
bigrob's Avatar
bigrob
Beautiful! What'd they Charge? Not sure when I'm gonna get to mine. Hopefully in a couple a weeks or so.
Old 08-30-2010 | 09:32 PM
CWhaley's Avatar
CWhaley
It improved the look tremendously!
Old 08-30-2010 | 09:34 PM
RPMulli's Avatar
RPMulli
Yes i know, it was $50 and they did it on the spot...
Old 08-30-2010 | 09:35 PM
RPMulli's Avatar
RPMulli
i just need to spray paint the weld job chrome and i will be good to go..
Old 08-30-2010 | 09:36 PM
CWhaley's Avatar
CWhaley
After it is all added up they are still cheaper then the Fabspeed....
Old 08-30-2010 | 09:45 PM
redridge's Avatar
redridge
looks good, but I think they should of cut it behind the tips....
Old 08-30-2010 | 09:56 PM
RPMulli's Avatar
RPMulli
Well they didnt cut completely through the pipe, they cut slice out, bent it up and welded the cut back together... That was the only spot to cut the pipe to "lift" it up..
Old 08-30-2010 | 09:57 PM
RPMulli's Avatar
RPMulli
It only cost me $170 total... pipes - $120 & fab job - $50
Old 08-30-2010 | 10:06 PM
redridge's Avatar
redridge
you can do the same.... angle the tips up, then slice behind the tips to angle it down... in this case angle it level. This way, you can get fairly close to the bumper to make it look stock position without seeing any weld mounts since it will be higher up tucked in the bumper.
No biggie, It looks good, Im just sayin.
Old 08-30-2010 | 10:22 PM
CWhaley's Avatar
CWhaley
your average muffler shop is not skilled in those arts young padawan!
Old 08-30-2010 | 10:36 PM
Ahmet's Avatar
Ahmet
Yeah really, it looks like they did a rather nice job. I'm also glad to see you still have your cats. Factory cats are fairly high flow, and do a bit of muffling of their own, not to mention the obvious environmental benefit to having them. Alas, even aftermarket mufflers are too loud for me, but to each his own.
You just made changing your spark plugs a 5 minute job while saving a lot of weight from back there!
Old 08-30-2010 | 11:13 PM
ivangene's Avatar
ivangene
Parts Specialist
I think you could get them to fit up a little better but this whole thread is
"I've been driving around for a week without mufflers"
"I basically bought them for the looks"
"They arent that loud. ( I used to work around jet engines all day, a flat six motor is nothing)"
WHAT ???
Old 08-30-2010 | 11:23 PM
RPMulli's Avatar
RPMulli
you know what i didnt even think about that, too bad i changed them about 2 months ago.
Old 08-30-2010 | 11:24 PM
Sneaky Pete's Avatar
Sneaky Pete
WHAT ???
Ditto
Quick Reply: Ebay Bypass Pipes
