996 Forum 1999-2005
I rolled it...
Old Aug 25, 2010 | 11:36 PM
achtung911's Avatar
achtung911
Default I rolled it...
the odometer that is, I rolled over 100k on my way home from work today
Attachment 469839
Attachment 469840
Old Aug 25, 2010 | 11:44 PM
losdeanos's Avatar
losdeanos
Awesome congrats!
I wonder what is the highest mileage 996 on the boards, anyone know?
Old Aug 25, 2010 | 11:51 PM
2K7TTMIA's Avatar
2K7TTMIA
whoa...congrats...and the temp gauge is running a bit hot ...were you stopped and idling after rush hour?
Old Aug 25, 2010 | 11:52 PM
achtung911's Avatar
achtung911
yes i was, and it was 90 degrees out side
Old Aug 25, 2010 | 11:53 PM
achtung911's Avatar
achtung911
is that something i need to fix?
Old Aug 26, 2010 | 12:09 AM
2K7TTMIA's Avatar
2K7TTMIA
It could be the angle of the pic, but I'd be keeping a close eye on the gauge with those temps.. Do you have a third radiator or maybe looked into the fan mod? Now those conditions easily happen here in sunny South FL; except I noticed when I have the AC temp set to LO, the fans up front kick in and blow a ton of hot air off the front rads, which may keep the temp in check. Or try to find a nice open road to run the engine a bit to bring the temp down some.
check Macster's temp in the pic below...that HOT! but the temp gauge is near sweet....pry on a nice open road keeping the air flowing ...
Old Aug 26, 2010 | 04:34 AM
Macster's Avatar
Macster
May not be "broken". Temp gages in these cars are not the most precise indicators of temperature. When my car encountered very high ambient temperature (116F) and the temp gage climbed to that region of the dial when I returned to dealer and spoke with the service manager about the conditions: 116F ambient; 226F coolant temp (read using an OBDII scan tool); 135F air intake temperature (ditto); service manager told me factory said that as long as the coolant warning light not on or flashing on the car suffered no harm from the elevated temperature.
If you want to know what the actual coolant temperature is buy an OBDII scan tool and use it to read the coolant temperature (and intake air temperature, etc.) in real time. The gage is there for decoration.
Check the coolant cap part number is 03 or 04. If it isn't you might want to replace the cap. The older ones leak. Also, check the coolant fluid level. If low the cap is leaking or there's a leak somewhere else. Coolant tank a common source of a leak.
With a properly sealed cooling system that can hold pressure these engines can tolerate a coolant temperature of nearly 250F without any boiling. But the ability of the cooling system to maintain pressure is critical. It is the pressure that raises the boiling point of the coolant. The anti-freeze is there well to prevent freezing and for some corrosion protection.
Besides, 90F not hot. This is hot:
Last July, coming across southern AZ/CA from Kingman, AZ to Needles, CA. Pic of my Turbo's dash.
Sincerely,
Macster.
Old Aug 26, 2010 | 06:20 AM
Pac996's Avatar
Pac996
I've got 114k. Have fun driving it even more and being amazed at how great of a car it still is with 100k+ on the clock. Figure 20k/tire set then 5 times $1600 avg for how many dollars in tires.
Old Aug 26, 2010 | 08:58 AM
Van's Avatar
Van
I'm up to 149k. (2nd engine, for all of you counting.)
Old Aug 26, 2010 | 09:39 AM
Chaos's Avatar
Chaos
Old Aug 26, 2010 | 11:58 AM
ohdavey6286's Avatar
ohdavey6286
I think I win the mileage 599,999 is where it quits ticking....
Old Aug 26, 2010 | 01:41 PM
Thundertub's Avatar
Thundertub
Cool
Macster,
What is that green light on the speedo?... the one with the pointer...
LOL!!!!!
(Macster)
Old Aug 26, 2010 | 01:48 PM
mikey55's Avatar
mikey55
62K and going on a 6 thousand mile trip the end of September, the second one this year.
Old Aug 26, 2010 | 03:16 PM
15psi's Avatar
15psi
104k, and going on a 3,500 trip this Sat. Can't wait!
Old Aug 26, 2010 | 06:14 PM
racer's Avatar
racer
Don't forget to clean out radiators once in a while.. lots of stuff crammed in there makes them less effective.
