996 Forum 1999-2005
DIY - changing brakes (video tutorial)
Old 11-21-2010, 10:59 PM
  #61
sharmat
sharmat's Avatar
Thanks for posting that very clear and concise video on the brake and rotor change. If i ever do it myself its a great reference tool. Very nicely done.
Old 12-08-2010, 05:25 AM
  #62
JDSStudios
JDSStudios's Avatar
Thanks Van.
Excellent tutorial!
Old 12-08-2010, 11:43 AM
  #63
babylonboots
babylonboots's Avatar
Awesome videos. Thanks for putting these together!!!
Old 07-07-2011, 01:33 PM
  #64
spender
spender's Avatar
This is one of the best video tutorials I've ever seen! Good job Van!
Looks like I may need to change my brakes soon, and I've make it my resolution to do more work on my car, I enjoy this kind of project. How much money is saved by doing this yourself versus having a shop do it?
Old 07-07-2011, 01:52 PM
  #65
spender
spender's Avatar
How much can be saved by doing your brakes yourself? What is the cost of just the materials versus having a shop do it?
Old 07-07-2011, 02:21 PM
  #66
seanmcr6
seanmcr6's Avatar
I did this job a couple weeks ago...I didn't protect my calliper when using the "big jaws" and I dented the paint DOH
Anyway....can anyone tell me how much brake fluid I need to change my brake lines? I have some nice SS lines to install...and I bought 2 bottles of Motul RBF 600 (totally 1 litre)...I just want to make sure it's enough fluid to completely bleed the brakes. (also, I'm using the motive power bleeder)
sean
Old 07-07-2011, 03:01 PM
  #67
Van
Van's Avatar
When I changed brake lines, I went through almost 2 liters...
As for the savings? Worst case, you save on the labor (probably a few hundred bucks) and the inconvenience of taking your car to a shop. Best case, you save the labor, get the parts at a discount to what the shop would charge you, get to build your knowledge and have the personal satisfaction of doing the job yourself. That could be priceless!
Old 07-07-2011, 03:20 PM
  #68
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Pad changes are really quite easy to change, it really is fun to get in there and be a part of your car.
Plus, a Porsche suspension is really quite cool looking, especially the rear. Lots-o-links!
Old 07-07-2011, 03:48 PM
  #69
function12
function12's Avatar
I replace all my pads back in Feb. I reused all hardware. The only thing I would do different the next time is to buy new shims. It was a pain in the a$$ to get the old shims clean before I put them back in.
Old 07-07-2011, 05:11 PM
  #70
spender
spender's Avatar
It looks like a pad change is super-easy, from the video, as you don't need to remove the rotors. Is this the case?
Old 07-07-2011, 05:59 PM
  #71
fpena944
fpena944's Avatar
Only reason to remove the rotors is to replace them.
Old 07-07-2011, 06:35 PM
  #72
spender
spender's Avatar
How do you know if your rotors need to be changed? Any particular signs to look for?
Old 07-07-2011, 06:52 PM
  #73
seanmcr6
seanmcr6's Avatar
Measure them for thickness. You can find the spec online (I don't remember it off the top of my head)
Check for excessive cracks between the holes. Some cracking is normal, but if any of the cracks spread far enough to connect to another hole, it's time to change.
Old 07-07-2011, 07:16 PM
  #74
DCP
DCP's Avatar
sean
I have used one liter when I have done my changes.
Old 07-07-2011, 11:52 PM
  #75
Van
Van's Avatar
For a regular flush, yes. But you might need more when you change the lines, because you'll introduce so much air into the system.
Quick Reply: DIY - changing brakes (video tutorial)
