2007 GT3 stock is 235 front 305 rear on 19s so I figure its good numbers. Since I'm running 19s and the GT3 rolls out of the factory cornering good I might try that. Bought the car used with 235 and 275s on 19s. Hopefully the tail wont be as inclined to break loose wearing the 305's.
Hey Pac, you might want to check that your rear wheels are 11" because a lot of aftermarket 19" rims are 10" wide in the rear and 8.5" in front (that's why you've got 235 instead of 225) and those 275's look like they're fitting OK.
With 10" rims you can go up to 295 (with some cursing of the mechanic) but any bigger won't work, ask me how I know
Originally Posted by 6C4GTS
I am intending to try some Michelin PS2 on my 996 C4S as a replacement for the current Pirellis and was looking at changing from 225/40-295/30 to 235/40-315/30 on the OEM rims. would appreciate any comments from C4S or turbo owners running this size on a 8x11 alloy.
If you look at the stock rim sizes for the 305's you'll see that they are 11.5" (for 997 wide body).
The 11's have 295's (996 wide body).
Putting 315's on a 11.5" rim will work, on a 11" rim 305's will work too, but with 315's... I think you're going to be 1 size over.
Guess there's only one way to find out.
