LED License plate lights and corner bulbs?
I'm very sorry I was stuck in some unexpected situations this weekend. As I go home after work today, I will get the info of the seller and post it up here right away!
The lights are very very simple to install, you need a phillips screw driver to open the light assembly (2 screws each light assembly) then you slide the rubber housing/gasket off, and pull the light out with your fingers. Then just reverse the steps. Once putting on the lights, it does have positive/negative, so if it's not lighting up one way just reverse them and bingo!!
I'll have all that info to you guys by the end of the day!! Sorry again..
Looks like that one expired...
here's the same thing off the same seller.
http://cgi.ebay.com/ebaymotors/No-Er...ts_Accessories
Topaz330ci, which one did you get?
Thanks in advance for your reply.
b-man
Both ebay links work for me at the moment. But they go to two different (but similar) products. They are from the same seller, but priced differently. Also, one says "36mm" and the other says "~37mm". There may be other differences too.
b-man
b-man
They look the exact same and that little mm difference shouldn't be a problem in anyway. When you install them, the tabs are very flexible and can be manipulated to fit.
I bought a pair from the second link as well.
