996 Forum 1999-2005
Door lock programming
Old Jun 27, 2010 | 08:23 PM
bigrob's Avatar
bigrob
Default Door lock programming
Do I have the ability to set my doorlocks to lock automatically when I start driving, or is this something the dealer must do?
Grazie!!
Old Jun 27, 2010 | 10:18 PM
gota911's Avatar
gota911
Newbies Hospitality Director
Dealer.
Old Jun 28, 2010 | 03:52 PM
bigrob's Avatar
bigrob
Well that is a drag!
Thanks!!
Old Jun 28, 2010 | 07:10 PM
Dennis C's Avatar
Dennis C
Rocky Mountain High
Can't you do that if you have a Durametric tool?
Old Jun 28, 2010 | 07:48 PM
reynwerkes's Avatar
reynwerkes
I wondered this also and called Durametric. Answer was "no".
Took my car to have it programmed. Not bad, about $60.
They also programmed my passenger mirror to dip.
Old Jun 28, 2010 | 08:17 PM
Marc Gelefsky's Avatar
Marc Gelefsky
Super Moderator
It's annoying because it's an easy change with my Vag-com on our Audi and on the Cayenne it's a menu item in the cluster.
Wish the Durametric was more robust like the Vag-com
Old Jun 28, 2010 | 08:36 PM
bigrob's Avatar
bigrob
It IS pretty crazy. Was able to on my Vett and GTO! Gonna have to c the dealer I guess behave my horn sound on upon arming also!
Old Jun 29, 2010 | 09:49 AM
frisbee91's Avatar
frisbee91
Exclamation
Originally Posted by bigrob
...I guess behave my horn sound on upon arming also!
If the horn sounds when locking the car (and arming the alarm), that may mean that one of the doors or hoods is not closed completely (or one of the contacts is not closing properly.)
Not sure if it's a programmable option to ALWAYS have the horn sound upon locking/arming.
Old Jun 29, 2010 | 12:20 PM
function12's Avatar
function12
Not sure if it's a programmable option to ALWAYS have the horn sound upon locking/arming. This is NOT an available option.
Old Jun 29, 2010 | 12:46 PM
Torontoworker's Avatar
Torontoworker
Not always. I confirmed with the local dealer that my car had been programmed for a single 'beep' when locking. They used their little PC pluged into the OB2 port to check and they confirmed it was in fact programmed this way and it gave the date it was done and and dealer code, (Vegas) so they said the previous owner must have wanted it this way. I only asked about it while I was there for another reason and the tech plugged in to check for me. I had read all over here that I must have a problem if it beeps when locking. Now the dealer did say to me that if I hear TWO beeps then thats a problem. Your most likey correct 95% of the time on single beeps - but there are a few cars people must have spent some money on for reprogramming. I could care less and wouldn't have dropped any coin to make the car beep but I was currious to find the reason out and the tech offered to check for free as he had to plug in anyway.
Old Jun 29, 2010 | 01:25 PM
function12's Avatar
function12
You get one beep if the radio connection taken off, glove box open, or center console is open. Many people including myself will push the micro switch out of the way on the center console. This will now give you the signal beep. I promise you on the 04 and older this can NOT be programmed. If you get a double beep you are turning off the interior mostion alarm.
I did lots of searching and asking dealer(s) and indies before I found the center console trick.
Old Jun 29, 2010 | 07:19 PM
philooo's Avatar
philooo
FUNCTION12, what microswitch are you talking about ?
Old Jun 29, 2010 | 08:11 PM
function12's Avatar
function12
If you look down into the latch of the center console you will see a small silver lever. That is the alarm switch. You take a small screwdriver and push the little lever/switch out of the way. Now the alarm will think the center console is always open and you WILL get a beep when you lock the car. Might not be a good solution for a cab but a coupe it works great. If you dont like the results you can always move the little lever back.
