anyone know what this leak is from?
I did the AOS check of taking off the oil cap and the engine seemed to run fine after a second of initial rpm changing with it off, there was a little suction but not to much.
Parts Specialist
+1 for an AOS tube IIRC -
AOS failures cause differant symtoms on differant cars for some reason. Oil consumtion is one thing it can lead too as well as noises, white smoke, small leaks, poor running or nearly any combo of these.
have you had yours changed? - Its a fun job !
Parts Specialist
I have heard some shops can do it in ~4 hours (for C2 6 speed) - it took me longer ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
it can be a good DIY if you have medium skill and some tools. Costs about $100/150 for the AOS.. you might need a new line or two
Is there a writeup on how to do this?
Rick
99 996C4
87 944S
