Is the GT3 mkI the most reliable, best handling WC engined Porsche ever built?
C4S is the M96 motor, most likely the worst for reliability. They were plagued with RMS, porus castings and slipped sleeves causing intermix issues, IMS bearing and breaking issues, faulty and shortlived MAF sensors on early models, AOS issues and some I probably missed. Porsche missed it with this, as it's a crapshoot if these motors will last 50k miles without major issues or even 100k without replacement. Once you make it to 100k or 125k you're probably good to go and can relax.
The GT2, GT3 and TT are free for all the above to my knowledge. The TT have their own issues which may be a little disconcerting but not catistrophic. The GT3 is probably the best handling and the most trouble free in my opinion.
This is all very good information for a potential 996 buyer. If it is appropriate, can we get this put on the official 996 buyers guide?
Mel
The GT2, GT3 and TT engines are rock solid.
Now the only issue that they all have and even the 997's is that the cooling pipes are glued into the engine block. Which results it them sometimes spilling out all their coolant. Not very safe when that happens to splash the tires and for the people who drive over it behind them. Coolant is very slippery and driving over it or it splashing on your tires will result in an accident for sure.
Define "rock solid"... ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
They're very good, but not totally immune to problems: https://rennlist.com/forums/racing-a...t-mosport.html
Also, they are all dry sumped engines.
Are they the only dry sumped engines on the water cooled Porsche's engine world?
Which one handles better?
Can you please elaborate more on that?
I'm glad you brought the 997 example... how does the DFI stands against the above mentioned dry sumped engine models as far as reliability is concerned?
The 997.1 shares the same M96 engine as the 996
I didn't bring the 997.2 9A1 DFI engine into the picture. We don't know what issues will come up with it. Though the Cayenne DFI engine has been out the longest and carbon built up related to DFI seems to be starting to rear it's ugly head.
I personally think that the new engine is a lot better then the M96, no more IMS and the oil pumps seem to be a good alternative for a dry sump.
I think if they dropped the DFI it would be a very reliable engine but then it wouldn't be able to get the fuel management that all the governments have put in place.
See the post above with the coolant issue. Happens on all the cars with this engine.
Which is the best handling 996 stock. The 996 GT3 RS is, followed by the GT3.
I've just read about the coolant issue. Thank you jumper!
So, are you suggesting that the 2.9 9A1 engine, which is not DFI, is the best bet on terms of engine reliability?
Not much on the power department, but handles like a dream... i guess i was unlucky then with the smoke issue!![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I should have bought it new instead...
not easily, and not without a Stupid Large Budget, unless someone has figured some major stuff out in the past year.
engine mounting points are different
trans would have to run upside down, also it's g50 bolt pattern
ecu
ruf did a few, 200K+
just buy a supercharger, or a turbo kit. If it blows up, replace with a 3.8L m97 and take your SC with you
ecu
Total of 2 or 3 motors ever returned to Porsche for porus castings.
As far as 'slipped sleeves'... pretty hard to slip them if you don't have them in a M96! Read Adrian's book (http://www.amazon.com/Porsche-996-Es.../dp/1845840968) where he lists this and other issues as old wives tales.
I think all this stuff is a little crazy, putting 20K+ into a 35K car so it can perform like a 996tt you can buy for 40K today so you can sell it for peanuts down the road doesn't sit well with me, but in a Cayman S I guess if you prefer the mid engine platform then it's the way to go. Me, I'd sell the cayman and buy a legitimate turbo, which does have the M64 block the OP seems obsessed with, and flash that sucker.
Adrian if you're still reading this board, maybe a clarification on porous block statistic?
Best,
Hans
If you speak to the actual Porsche independent shops, they'll tell you the M96s are reliable and the GT1s as well.
I know of cases where the GT1 turbos have gone to **** and that's an expense that well exceeds any M96/7 replacement project. And you're not even getting a new engine.
Just buy it, drive it, enjoy it. It's a Sisyphean endeavor this thread.
Yes, the engine smoking at startup and smoking while running could just be the air oil separator. Though smoke at start up is not uncommon and nothing to worry about for an engine that is horizontally-opposed. Oil can easily leak through the rings during cooling periods and lie in the cylinder and at start up be burnt off.
Can you recall seeing a sound GT3's engine smoking from tailpipe ?
Those who buy 911's - and i just might became one - are only buying what Porsche is willing to offer... not the best they can offer for the same money!
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
