obdII code help
Not really anything to worry about there. The alarm codes are common, usually mean a door left open, trunk or something like that. Others shown are not major. No engine codes shown. Looks like this was done with a standard OBD reader. I would be nice to see a readout with a PST2 of a Durametric so you could see hours on engine, over revs, etc. If you are thinking of buying the car invest in a PPI, it is worth the few hundred dollars.
Thank you. That's good info. These readings came with an inspection package from the owner who had it done at a local indi mechanic in Escondido, CA. Only the brakes showed up as suspect with about 25% wear left. I will ask about getting the Durametric printout and if my offer is accepted I am going to have compression and leak down tests performed.
Thanks again for your help.
Jeff
Future 996 owner
