Cam cover gasket change
#31
To be honest I just gave each a quarter turn. *GASP*, der sphinkter latent krauten das torquen! It's a valve cover guys, it's not like INTERPOL is going to show up at my house for violating Porsche torque specifications.
#39
The cover wants to be tightened down properly and without any twist so the camshaft bearings are not compromised.
Sincerely,
Macster.
#42
i had the same problem to my 996 4s. Mine was leaking from pasengers side. The problem was the right valve cover flange so i replaced it. The car dont stop leaking and my mecanic change something like oil valve (uper area from valve cover) and snugging up a little more the cover bolts.
When he do that i have no leaks isues...... Total cost 500 euros not in PORSCHE DEALER
#43
This is kind of a old thread but I just got the same leak on my 00 carrera. Mike99 what ended up being the issue was it the cover or the spark housing? How much did it cost? How long did it take?
#44
This rig is a joke..
Everything about resealing the cam covers is a complete nightmare!... just pull the motor... 1st getting to the exhaust brackets is ultra tricky but can be done 2nd getting the exhaust out without pulling the rear bumper is no fun 3rd 5 of the 10 exhaust manifold bolts broke off due to electrolysis drilling up and metal coming down really sucks... eventually you'll be pulling the motor so might as well get it over with... I am actually replacing the vvt solenoids... or was... now I'm replacing the rear main seal cam cover seals exhaust bolts pcv/crankcase vent valve and clutch... this is what you can expect...
#45
