Radio Questions, yes I searched
Is the unit in the 99 with cassette and 6 disc changer a Blaupunkt?
If so, what are the chances a later model Blaupunkt will be a direct fit?
Does anyone have a pix of the removal keys?? If so i will just go pull the radio and look myself
These are what the removal keys look like
http://www.soundlabsgroup.com.au/p/B...oval+Keys+MkII
From toolpants at Renntech
The Porsche CDC-3 changer is the same as the Becker 2660 changer. It is a Sony changer with Becker electronics. When I started in 1999 some people were using Sony changers, because it was cheaper than the CDC-3 from Porsche. Once we figured out the Becker unit was not much more than the Sony units, we started to use the Becker 2660, as the Becker cost a fraction of the Porsche unit.
So, the connectors you see look like a Sony for a reason. The changer was made by Sony and branded Porsche or Becker. And that is why when we wanted to buy an extra magazine we bought it as a Sony part, rather than from Porsche or Becker.
You would have to find a Sony unit from around 1996. I think it was CDX-T60 or CDX-T62 and maybe CDX-T65. If I remember correctly there were also 6 or 10 disc units, just like what Becker sold. Porsche only sold the 6 disc unit. With the Sony unit there might also an issue with the GAL feature, or you needed an eprom, or something. I don't remember, as once we started to use the Becker 2660 people were no longer using the Sony. Plus you could not find a new Sony, as Sony changes it's products every few months, and Porsche/Becker every decade.
But then even Becker discontinued the 2660 a few years ago. It was replaced by the Becker 7860, but never sold by Porsche. The 7860 works with the 210 and 220 radio heads, but has a memory issue and is smaller so it is not a direct fit on the factory mounting bracket.
