Installed: H&R Sport Springs (How-To Included)
#31
I orederd a new set of rear shock (Sport) which it turns out are longer (about 1.5 inches) than the HDs, and now my HR springs wont fit without a lot of compression.
Is it possible to run without springs in the rear and if so, what kind of a ride can I expect?
Thanks for your quick response, folks? I'm in the middle of the job!
#32
I'm an old air cooled guy, with torsion bar suspensions, so the whole multi link thing is a little new to me!
All back together now. I had to just compress the springs (H&Rs that were already on the car when I bought it) down more to be able to reassemble the shocks.
I did end up tearing the lower toe arm ball joint grease boot though. Can anyone recommend a replacement boot that would fit and seal well? I see universal one out there but thought there might be something a bit better and I'm not reat to replace the whole arm yet just to get a new ball joint!
Thanks again!
Thanks again!
#33
Thanks for the DIY, I'm going with KW HAS though.
ECS sells this socket, easier to use an impact wrench on the top strut nut for cars with PASM. This way you can torque correctly.
#35
OEM Frt upper strut mounts or Tarrett Camber Plates?. Installing B-8's and H&R Springs on my 1999 C-2, cant decide if I should use OEM strut mounts or pay the extra cost and install Tarrett Camber Plates or something similar. My goal is to get about -1.5 negative camber at the front, not sure I can do that with stock strut mounts. Track the car about 6 or 7 times a year, not a daily driver. Any feedback from similar installations would be appreciated. How about rear strut mounts, never see any discussion about them, I assume stock is OK with this setup.
#36
No! You can't run without springs...![nono](https://rennlist.com/forums/graemlins/nono.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#37
The poster mentioned this
"the only special tool you will need is a 21mm strut nut tool, which allows you to hold the strut in place while removing the 21mm strut nut on the top of the assembly. I purchased this from German Auto Parts - $42. http://www.germanautoparts.com/productdisplay/4970"
Is there an alternative tool for this? Anyone rent one from an auto parts store by chance?
#38
#39
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/800x600/untitled_a87afffe2eddc1fe3f5274ba0576cba7863c35d2.png)
I began the process of replacing all my stock springs with the H&R's and also the front upper strut mounts and bearings. I'm now at a stopping point because I can't remove the bolt that attaches the lower part of the strut to the wheel carrier on either front side. It's extremely seized up. I've soaked it several of times with PB blaster also. Haven't attempted the rear struts yet. What i'm wondering is, is it even worth the fight of removing that lower bolt? Wouldn't it be possible to replace the upper strut and spring while it's still attached to the carrier at the bottom? (as it is in the picture) I've already got the spring popped off the bottom strut mounts so there is no need to compress it to remove them.
#41
^This^ is a great idea! A "steamer" may work with a fine tip as well... definitely better than a torch/open flame... It took me a week of really hard work to get one of my strut to wheel carrier bolts out. Take your time so as not to damage the carrier... you'll get it eventually.
#45
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/800x600/20171024_232651_e8e541d610af137786949b218c8b91f896a9ea8e.jpg)
