Oil capacity and oil change questions
Knocked out my first oil change this weekend. Got real dirty but I felt like a man. After 9 qts. (I thought that was the capacity on a 3.4l) I was at the bottom of the fill range. Added 1/2 quart more and I am now in the middle. Was going to put in the rest of the bottle (in increments checking frequently) and am guessing that will get me to the top of the rage. This will be a whole quart more than I thought. Have let the engine run and get up to operating temp a few times to check for any variability. Did the new washer, filter, etc.
Am I doing it right?
Also found a few metal filing fragments in the pan. Is that ok?
3.4l with 70,000 miles.
Thanks for your input
dont OVER FILL - a little low is better than ANY over full
metal might indicate wear somewhere that matter, or doesnt. I would recommend changing IMS to the retrofit and checking the tensioners. Those are high suspect of having issues. If you cept the oil filter, cut it open and look around inside... see what you find and report back.
This may sound dumb but you have to check if they are really metal by grabbing a magnet and running it through the filter, (which you can cut open). Sometimes what looks like metal is carbon that has flaked off parts. Bearing material (which is not good) is steel and will stick to magnets. Thats why some people spend a few bucks and buy the magnetic oil drain bolt as a quick way to spot trouble.
I'm not sure what you mean by 'pan'? Are you saying you removed the pan or did you mean the oil filter housing?
Be sure you correctly insert the dipstick into the dipstick tube to take an accurate reading of the oil level. The car wants to be level and the engine should remain off for some time. How long depends upon how hot the engine and the oil got. At least a half an hour or so. You can use the in-dash display timer to see how much time you need to wait before you can use the dip-stick to check the oil level.
It is better to be a few bars below maximum than to be at maximum. The oil will expand some when it gets hot and the engine can be a bit overfilled. Not horribly so but still, you want to avoid this if you can.
Metal debris in the oil poured from the oil filter housing a bit troubling, but it depends upon the type of metal and the amount.
The engine is of course made of cast aluminum and pieces of cast flashing or even swarf left over from when the engine was made can come loose and end up in the oil filter housing. The oil filter is doing its job to trap these and block them from making their way into the oil supplied to the rest of the engine.
However, if the metal bits are magnetic (ferrous) this is particularly troubling. The crank, rods, cams, cam chains, valves, valve springs, zero-lash lifters, valve retainers, piston rings, piston pins, and the various scavenge and pressure oil pumps all consist of ferrous metal parts. But if any of these were shedding metal on an ongoing basis I think you'd know it by now without having to rely upon what you find in the oil.
The engine's main and rod bearings are made of non-ferrous metals.
There is another possible source of ferrous metal debris in the oil: The IMS bearing (a ball bearing) has of course ferrous metal ball bearings, and ferrous metal inner and outer races. The ball bearing cage is I believe made of a non-ferrous alloy.
If the metal non-magnetic and shiny chances are it is aluminum. Unless there is heaps of it, not to worry, maybe.
If the material is non-metal, dark almost black, or dark caramel colored, this is likely the composite plastic camshaft tensioner/guide rail material. Some -- not too much -- is probably nothing to worry about. Lots could be signs of one or more guides failing. If the material separates from the rail, then the chain runs against the metal (aluminum) guide/tensioner rail and this will quickly have the oil filter loaded with fine shiny/bright metal flakes. The engine could make some racket too. In fact, I would expect it to make some racket cause one or more cam drive chains running against metal vs. composite plastic.
Without pics it is impossible for me to say how serious, or not, the presence of metal is. Even with pics my opinion is still only my opinion.
One thing you can do, is get the oil level right, then provided the engine is not making any noises and not exhibiting any untowards symptoms start the engine and let it idle then if it continues to behave take it for a drive. No need to thrash the car or the engine. Bring the car back and remove the oil filter housing and pour the oil and filter out into a clean drain pan and examine the oil and look for any signs of anything, any particles in the oil or in the filter fibers.
Very important: If at any time the engine begins to act up, make noises, as soon as safe to do so, shut off the engine and do not start it again until you have the engine examined by a qualified tech. Serious may be even fatal engine damage can result if you continue to run the engine, even start it again for a brief time. Almost never are engine noises ever made better by continuing to run the engine once the noise or noises appear.
If the oil is clean, undiscolored, and free of any metal or other material bits, install a new filter element and top up the housing with clean oil then install and torque it down properly.
If the oil has metal or other material bits in it... Well, post what you find first.
If you removed the oil pan that you found some metal is not surprising and the pieces could be large.
New engines shed alot of metal (and other material) from new and most of this stuff shed makes its way into the the sump the oil pan where it remains forever unless or until disturbed by someone removing the pan. A few of the smaller pieces might get inhaled or ingested by the oil pick up tube and of course after being run through the oil pump will end up as very tiny metal or non-metal bits in the oil filter housing oil.
If the oil pan was the source of the metal bits and the oil in the filter was free of metal of metal bits or a second examination of the filter oil turns up no more metal bits then the metal you found almost certainly an artifact from when the engine was new.
Sincerely,
Macster.
Wow, thanks for that complete explanation. To clarify, the bits (about three of them) were in the pan that I drained the oil into--not the oil pan. I'm not sure if they came from the oil or the filter as I didn't see them until I had already dumped both and slid the drain pan from under the car. I did not cut into the filter but there was no debris evident. I did not save any of this but will the next time. The car runs great with no noises or issues of any kind but I will be on the lookout and will do a better job of examining the evidence next time around.
Well, now you know: Next time check the pan and clean it before you drain the oil to avoid scaring the H*ll out of yourself.
Now to contradict myself: I don't bother looking the oil drained from the oil sump (Boxster) or even the engine and oil tank (Turbo). This oil drains into an enclosed container that has who knows what in it. I do look at the oil stream as it pours down into the drain pan and I like to see the oil is not completely black/opaque. I treat the car (all my cars) to 5K mile oil changes so sometimes the oil is still a bit translucent and in fact once or twice when the 5K miles all covered at highway speeds over the span or a week or so (road trip!) still has a hint of amber color to it. I have nearly 230K miles on the Boxster's original engine and I'm not about to fret over some oil that might have a few hundred or even a thousand miles of useful life "left" in it.
Anyhow, what I do for the Boxster is when I remove the oil filter housing, I carefully pour the contents of the housing into a smaller and very clean drain pan then look at the oil and look at the filter too. So far nothing disturbing has appeared.
With the Turbo, its oil filter is upside down -- on top of engine -- and all I can do is look at the filter element, when I change its oil. So far I've broken down and had the dealer change the Turbo's oil/filter about as many times as I have. The Turbo's oil change a bit messy -- more so than the Boxster's -- and I have no real good place to work on the cars so in the case of the Turbo I let local Porche dealer's service department change the oil/filter.
Sincerely,
Macster.
Here's an update on capacity. I checked the dipstick tonight and it looks perfect. The electronic guage says we're two bars short of completely full so we're good to go there. Surprised it took a dozen miles and 24 hours for the oil level to "come up". Obviously the oil didn't come up but the measurement devices did. Thanks for the input and I will check the oil from the filter and filter next time.
Oil change on a 996
Tomorrow I'm going to change the oil on my 2001 Porsche 996. Is there anything that I should know about changing the oil filter. I know that it's a cartridge filter, and today I bought the filter. Do I need a special tool to remove the housing on the filter. I assume the rest is pretty straightforward, just removing the drain plug and let the oil drain out.
This is the first time that I am changing the oil.
Appreciate your input.
There should be a DIY in one of the tech forums here. Suggest you find it and download it and read it and memorize it.
You need a proper sized wrench for the filter housing. The filter element should come with a new housing o-ring and you need a new drain plug washer. That's an oil drain plug seal, actually, and should not be re-used nor should you try to substitute something else.
The oil comes gushing out. 8+ quarts of oil. It will probably be warm, if not hot. Be sure the oil drain pan is big enough to hold the oil. I use an enclosed pan that has a funnel like top surface with a hole in it to let the oil run into the container proper. The problem is if one drops the drain plug it will almost certainly block this hole and the oil will back up and overflow and make a mess.
(But I like the enclosed pan cause I just put the plug back in the hole, close the air vent, wipe the funnel surface down with paper towels than I can carry the pan by its plastic handle and dispose of the oil with no muss no fuss.)
Install the drain plug with its new washer. Tighten it down to its proper torque setting. 39 ft lbs IIRC, but the DIY instructions will have the right torque setting.
Remove the oil filter housing and carefully tip it into the drain pan. If you want, tip this oil filter housing and its oil into a clean pan and examine the oil for stuff.
Remove the filter element. Clean the housing. Remove the old o-ring and install the new one. Be sure the ring is in the ring groove and not partially in the housing thread groove. Put the new filter element in the housing. Press down a bit so the element seats on the spigot at the bottom of the housing.
I like to fill the housing up with clean oil and take a clean finger -- I use mechanics rubber gloves and change them several times during the process -- and smear some clean oil on the housing threads and on the o-ring.
Be sure the aluminum bore the housing and its ring fit into is clean and hand start the housing to make sure it doesn't cross thread. You should be able to screw the housing all the way in until the o-ring reaches the aluminum. Be sure the o-ring is not caught and tearing as you tighten the housing and torque it down. The oil on the o-ring helps prevent this. 19 ft lbs IIRC, but double check the DIY instructions.
Add fresh oil of the proper type and amount and before you start the engine check underneath for any leaks. (I've never done it, but a friend of mine left the drain plug out of his motorcycle engine and ended up with a nice puddle of fresh oil under the engine...)
If you're sure everything's cool then check everything again.
If you're sure everything's cool then turn the key to on and check to be sure the oil light comes on before you start the engine. Start the engine and check the oil light goes right out.
If it doesn't... shut off engine and check the oil level.
Also, as a habit, I like to give a listen just to make sure the engine sounds ok. If you forget the oil though anything you hear will be expensive to repair.
Drive the car off the ramps onto level ground then shut off the engine and put away tools and clean up.
Check the oil level with the dipstick and add more oil until the dip stick shows the oil level at the sweet spot.
Take car for a nice drive.
Sincerely,
Macster.
When replenishing the oil it helps to have some oil in the filter already.
Then on your first start do not go out and just drive. You have to make sure the new oil replaces and air spots created by the pumps initial pumping of air and oil when doing the first start. Something like that
Oh 3 minutes of letting the car idle is the normally advised period for a first start with new oil.
My question is, since i bought my car about 4 years ago at 45km i have been chaging my Oil every 5-8KM but the Oil comes out Clean (also noted by my Indy)...
-Is it really worth changing the Oil so Early?
-Am i blowing my money away?
-Should i change my oil every 24km as per Porsche?
-Maybe Half Way @ 12Km is fair?
I do no more than 5 Track Days a Year, mostly Street Driving and use Factory Mobil 1 0W40
