My car has the bearing/support upgrade finished
Here you have lots of pics:
My mechanic finished the work.
My car has:
- new SKF hybrid ceramic compound ***** bearing/steel hub
- new 12 mm bearing support F125 steel
- helicopter engine special seals (the best material to seal for high temp)
- OEM 3 flange end piece modified to place the new bearing support
- Valvoline VR1 racing 5W50 engine oil
The bearing support and the the 3 flange were made/modified by an expert lathe operator.
besides the oil filter/oil filter adaptor/magnetic drain plug purchased to Raby were installed.
Link with pics:
http://www.pasionporsche.com/compone...ms-996-36.html
My car has:
Link with pics:
It's due to my bad english.
I only discuss with an engineer , the mechanic and one of the best experts...
I didn't add anything.
Everything was made by a soloporsche fellow before.
I tried to get it done by my mechanic following the same way to proceed as he did
More links of the help we had from our engineering.
http://soloporsche.com/showpost.php?...&postcount=203
http://soloporsche.com/showpost.php?...&postcount=214
http://soloporsche.com/showpost.php?...&postcount=222
I'll try to translate the explanations from my mechanic
He is very ironic and told about that the bearing was the same as MotoVespa (scooter) engine, ha ha ha
http://translate.google.com/translat...tbb=1&ie=utf-8
How's the translation here? I saw it mentions Scooter like you did. Oh, and a few cussing too
Un saludo Para Espana de mi parte Vale...
pac, you have a nice looking car
