My new lift (Nussbaum Sprinter Mobil II)...added more photos
#46
That looks like a good lift. Is it the short rise version on their site? Also, I just realized that you cant raise the car without the wheels attached, right? What if you want to do a suspension swap?
That thing looks pretty well built, but scissor lifts always scared me. There's so many of them out of china that are downright dangerous. I went a much simpler route and got a Kwik Lift from www.kwiklift.com . I feel much safer under it. Next house will have a 2 post lift, but that's another story.
![](http://img.photobucket.com/albums/v306/Budmanv2/IMG00633-20100524-0641-1.jpg)
#47
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
The "net" lifting height is, according to available to me literature 880mm. That is 982mm overall height extended less 102mm ramp height. Imperial minds need to convert to inches. So, it qualifies as short rise for sure.
As to rising the car with or without wheels attached, you have to drive in on the lift first (with your wheels attached, preferably), support your car (stock lifting points) using four urethane blocks, rise your car and then remove wheels, suspension or whatever else your soul desire.
Google Nussbaum sprinter in PDF format and you will see more pics and dimensional info.
#49
![Wink](https://rennlist.com/forums/images/icons/icon12.gif)
So, it finally arrived in my garage last Friday. Took me a day to unpack, and set it up. I did it all by myself, however I would not recommend it unless you are like I and willing to use a long bar, floor jack and a number of other tools including hammers and stuff...
You will need 8 liters of hydraulic fluid and a 240 V 6-20 wiring and a 6-20 plug since the cable on Nussbaum lift comes without any plug. Just bare wires. Post #44 is not entirely accurate, you will need just over 2 gallons of hydraulic fluid. I used just over 8 liters to be just under max. mark on the dipstick.
First impressions: I was hoping to be able to lift my car(s) a bit higher. Well, other than that it's quiet, smooth and nicely finished. The manual is in German, but you don't really need much. All straight forward. Fill fluid tank, attach power plug and enjoy.
Overall, quite happy.![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Cheers,
L
Cheers,
L
#50
Cheers,
L
Cheers,
L
#53
Hi Pete,
I need to use some 2x10 to extend and raise the ramps a bit after the x74 but it all works out very well (see pic in post #35). With x74 on the lift, the wheels are no longer dangling so they just suspend nicely once lifted whereas with stock suspension, the wheels will dangle and rest on the front extended ramp.
