996 Forum 1999-2005
I'm Going in ALONE....LNE Retrofit bearing
Old 03-21-2010 | 03:05 PM
  #391
Eharrison's Avatar
Eharrison
Originally Posted by Shark Attack
Yes, it is a very physical job from start to finish, especially on your back.
That's what she said.
Old 03-21-2010 | 03:15 PM
  #392
garrett376's Avatar
garrett376
No, Its doesnt "click in" like a chebby. We all seemed to have this issue. No I didnt use a lift. I didnt even jack the whole car. Just the *** end.
OK... I figured it might click in, after about 2-3 hours of trying various angles, I finally resorted to slowly tightening the bolts which brought it together easily and things still rotated with no issues.
My wife thought I got sunburned on my back - just abraded from laying down there for so long and wresting that thing!
With 964 engines, and 901 engines, they pop right together once the correct angle is obtained! Not my 996!
Old 05-13-2010 | 12:00 AM
  #393
logray's Avatar
logray
stand by, it will be posted on this reply
OK, LMAO on this particular pic of the engine support. I would do the same thing... but with a little insurance in the form of another floor jack or second "stick of wood"! HAH!
Here's the official TOOL BTW, you tool! **** those money grubbing tool WHO - OARS!
http://www.etoolcart.com/enginesupportbarforthe996.aspx
Which is actually inferior to your gold plated design.
Condiering an IMS on a 99' C2 w/70k miles...
Old 05-24-2010 | 05:30 PM
  #394
logray's Avatar
logray
I'm diving in for this repair as well and you can follow it below (hopefully kosher to cross post to another forum). Thanks Shark for the excellent write up!
http://www.renntech.org/forums/index...0&#entry177376
Old 05-25-2010 | 02:05 AM
  #395
logray's Avatar
logray
Did you pull your a/c compressor/etc. and remove the tensioner on top of the block? It looks like according to your post you didn't do this, and only removed the two easily accessible tensioners on the bottom for 1-3 and main tensioner side near oil filter, and you were still successful... despite not pulling your caps to verify timing.
I'm doing an ims replacement and didn't pull #3 on top of the block behind the A/C Compressor before pulling the ims hub cover/flange and could use a second opinon or verifiction of what you actually did.
Thanks in advance!
Old 05-25-2010 | 11:33 AM
  #396
Chris996's Avatar
Chris996
LNEng is stated you don't have to pull the #3 Tensioner. With the cams locked at TDC (+-180) (TDC1 or TDC2) the timing is not being compromised.
Old 05-25-2010 | 01:12 PM
  #397
logray's Avatar
logray
Thanks Chris, this is what I am reading and hearing as well...
Old 05-25-2010 | 01:19 PM
  #398
RPMulli's Avatar
RPMulli
You don't need to pull out the third tensioner just the two located on the bottom of the block...
Old 07-06-2010 | 07:59 PM
  #399
HoosierChristian's Avatar
HoosierChristian
Just had to post that this is an awesome write up. I am looking for a 996 but almost passed on the idea do to the IMS issue. Now that I see what can be done, I'm moving ahead with my search. Thanks Kyle!
Old 07-06-2010 | 10:56 PM
  #400
Shark Attack's Avatar
Shark Attack
Very glad to hear I helped you choose a fantastic car.
Old 07-27-2011 | 09:20 PM
  #401
sa321's Avatar
sa321
wow what a thread! thank you.
one question came up as I played with just arrived LN bearing and tools.
The thread on new center stud doesnt fit LN tool kit. So once I install new bearing I am completely screwed with no way to replace it? Hm.. unless I am getting it wrong I ll soon be selling my new LN tools (only used once).
Old 07-28-2011 | 12:02 AM
  #402
Shark Attack
Im sure they will make a new adapter to fit.
Old 07-28-2011 | 01:10 AM
  #403
pterfloth's Avatar
pterfloth
You can extract the LN Bearing with their kit. Tap the center stud gently into the IMS, insert the easy out nut and wire, screw the extraction tool threaded shaft (minus the hex adapter) into the nut, and extract as you would the OEM bearing.
Old 07-28-2011 | 05:07 AM
  #404
sa321's Avatar
sa321
thank you. didnt think of that
Old 07-28-2011 | 07:59 PM
  #405
Shark Attack
The thing I see thats going to be tough to get out is that coiled type retainer ring that holds the new bearing in place.
Quick Reply: I'm Going in ALONE....LNE Retrofit bearing
