Oil leak need advice
Hi, I'm new into Porsches, I bought last Dec. a 2002 C4S with 57K miles.
And I noticed oil on my garage floor underneath the car.
I took few pictures and I would need you konwledge and experience to found what is the problem with the car.
Thank you all
Sylvain
2002 C4S
2007 Cadillac Escalade
2006 Corvette C6 conv ..sold
1971 Olds 442..sold and missed
Thank you all
Sylvain
2002 C4S
hello and welcome....
when you get time shoot us a couple shots of the car too
Anyhow, ya got quite a little leak there. any chance of a pic a little farther away so I can orientate the shots. also any on the side of the motor... thru the wheel wells... ect
a good start would be to clean up the area so you can look for fresh drips now that you know about where to look and know to look........
also a side note, the oil looks a bit dirty, when's the last change?
Thank you Ivangene,
I will have the car lift to get better pics
the leak is located in the middle center of the engine.
I have been told that's the RMS.
I will post pics of the car also
OK here is the sad facts.
The oil is from the rear main seal or the IMS bearing. I have been told IMS oil is burnt black becasue of the way the oil gets stuck in the IMS tube and cooks till its black. RMS oil will be the same color as the oil on the dip stick. So if it is black burnt oil. STOP DRIVING THE CAR until you have it checked out. If it is the RMS. its yoru call to put up with it or spend the $$ to have it replaced.
First task is simple. Clean things up under there then wait and watch for where the oil is coming from. Tool are rag and good soap like spray on superclean or possibly even a long bristled brush to get in the deep areas. Could even be the air oil seperator leaking down.
I am not suggesting to "use" anyone, but with a genuine interest in trying, can get help if they are willing and have the time to spend
Couldn't agree more since Ed helped me with putting my tranny back in, the car is still running great.
