GT3 brake duct spoilers - worth it?
As for the scoops, they do help. But you need to keep the entire braking system in mind. If you are running street tires and stock-ish pads, they will make a fairly substantial difference on cooling. If you are running r-comps and aggressive pads, just the scoops won't be enough. You will probably need better cooling in general- possibly including GT3 ducts, GT3 scoops, SRF, and slotted rotors.
Personally, I do not recommend the cup scoops. The may be great for cooling while they are attached, but drop 2 wheels and your $125 scoop is history. They also scrape driveways and other inclines as they are substantially bigger than the GT3 ducts.
-td
Are you overheating your system now?
-td
-td
Since the ducts are fairly cheap, I was curious. Even though the 911 is about 300 - 400 lbs heavier than the RX8, the brake system should be fine for my level (NASA level 2).
