Cost for 90k service??
Rocky Mountain High
My local dealer wants about $1,300 for it. I don't remember the exact number.
Newbies Hospitality Director
Major maintenance after: 30,000, 60,000, 90,000, 120,000 miles etc.
Diagnosis system: Read out fault memory
Polyrib belt: Check condition
Change the engine oil and oil filter
Replace the spark plugs (see below for frequency)
Vehicle underside and engine compartment: Visual inspection for leaks (oils and fluids) and abrasion (lines and hoses)
Underbody panels: visual inspection for completeness, installation and damage
Coolant hoses: Check condition;
Radiators and air inlets at front: Visual inspection for external contamination and blockage; Coolant: Check the level and antifreeze protection
Air cleaner: Replace the filter element
Particle filter: Replace the filter element
Fuel system: Visual inspection for damage, routing and secure fit of line connections
Power steering: Check the fluid level and bellows
Parking brake: Checking the free play of the parking brake lever
Brake system: Visual inspection of the brake pads and brake discs for wear
Brake hoses and lines: Visual inspection for damage, routing and corrosion. Check the brake fluid level
Clutch: Check the play and pedal end position
Steering gear: Visually inspect the bellows for damage
Tie rod joints: Check the play and dust bellows
Axle joints: Check play, visual inspection of dust bellows for damage, check screw connections of running gear adjustment facility, front and rear, for secure fit
Drive shafts: Perform a visual inspection of the boots for leaks and damage
Exhaust system: Visual inspection for leaks and damage, check suspension
Tires and spare wheel (collapsible wheel): Check the condition and the tire pressure
Check the door locks, lid locks and safety hooks of the front lid to ensure that they are secure and functioning properly:
Check lid lock, front and rear; Check safety hook, front lid; Function test, check door lock; Check door and lid tightening torques
Seat belts: Check function and condition
Vehicle lighting: Check function; All headlights: Check adjustment; Horn: Check operation.
Windscreen wiper/washer system, headlight washer: Check fluid level and nozzle settings, pay attention to antifreeze protection in the winter months.
Electrical equipment as well as warning and indicator lights: Check operation.
Test drive:
Remote control, front seats, foot and parking brakes (also actuation travel), engine, clutch, steering, transmission, ParkAssist, automatic speed control, TC/PSM switch, heating, air-conditioning system and instruments: Check operation.
Oils, fluids: Visual inspection for leaks
Additional maintenance every 90,000 miles
- 911 Carrera (996) up to and including MY99 (X) every 30,000 miles
- 911 GT3 (996) every 30,000 miles
- 911 Carrera (996) MY00 (Y) every 45,000 miles
- 911 Carrera (996) as of MY01 (1) every 60,000 miles or at least every 4 years
Test drive:
- Manual transmission: - Changing transmission oil
- Automatic transmission:
- Replace ATF or Replace ATF (as of 2002)
- Replace ATF filter or Replace ATF filter (as of 2002)
- Change transmission oil in final drive or Change transmission oil in final drive (as of 2002)
- Final drive, front: Change transmission oil in front wheel drive
