Oil change
#92
Pretty much if its hot or typically warm weather use straight 40, 15w50 or something with a thick blend.
Normally lighter oils are recommended in cold weather. I think it helps the oil make it into areas during the initial start up which prevent the engine from being worn out from just run up at start.
#93
#95
I've got something similar to that on two of my cars and it's awesome, but I wouldn't put it on my Boxster due to the location of the plug. You'd be able to throttle the oil better, too, and keep it from overflowing your drain pan.
#96
That valve would be sheared off in no time, and then you will have a real nightmare on your hands. The drain plug is already rediculously easy to get at and drain. I wish all my other cars were as easy to change the oil on as my 996.
