Dead battery question
You can always remove the fuse cover kick panel by the driver's door/left leg, grab a battery jump box and attach the hot to the post inside the fuse box (pulls out, I think orange in color?) and the negative to a convenient ground. That will give you enough power to start the car, open the trunk(s), etc.
Yes, it does not need much power to open the hood. You may even get the hood to open with the charger if the battery any life in it at all.
Otherwise it is the fuse box thing as described above.
Tony c
Tony c
my battery went dead and I've been trying the fuse box route. Unfortunately, all that happens is the alarm goes off for 60-90 seconds. Since it's in alarm mode, the front boot won't open.
The dealer recommended using an old cell phone charger and powering it with the jump box. no luck yet, but still trying.
there has got to be a release lever somewhere in the car!!!!!
Much missed
Under the front fender, passenger side, pull the alternative release wire. The wire is approx parallel with the release latch.
You can do a search for the diagram.
Much missed
I'm not sure what you mean by "get the latch to reset". Look at another thread about 3 days ago. It covers taking the latch apart and re-working the spring. Good luck!
