Can't clear CEL, code P0455
I have had the CEL light on for a couple of days, so I bought a code reader tonight. I hooked it up and it showed P0455. I was expecting that, as I have had it a few times before, and it was always a loose gas cap. The problem is that I can't get the CRL light go off. I do an erase cycle, and the light stays on. I an using the reader properly.
Any ideas on why the light won't go out. I have been here for a couple of hours doing searches, and it seemd like everyone clears codes and turns off the lights all the time.
Johnny
Johnny
Before you send the car to the mechanic, what you can do is check for any disconnected hoses (vacuum hose) or wiring under the hood. Check also the air filter whether it is clocked or not. If you have spare air filter, replace the old one and check if the warning light stays off or not.
I hope the above helps.
If you don't fix the problem then the light gets turned on again by the DME.
P0455 says that fuel system vapor leak test is failing (required by US EPA and most states smog tests).
This test is run at every engine start.
Most likely causes are a bad gas cap o-ring, a bad gas cap, or badly leaking EVAP canister )or one of the EVAP lines).
You need to fix the cause to get the light to stay off.
Thanks guys,
Loren - I was thinking that something must be really really loose or bad to have the light go on so fast.
I am going to check something else out. I have a detached garage in my back yard that I keep the cab in, and unfortunately there has been a bunch of mice living in there too. I have been slowly getting rid of them, but one of them may have gotten up into the car and chewed a wire. I saw this as a cause in a couple of posts. I am going to keep thew car out of the garage until all mice are gone. What a pain in the butt.
Johnny
Johnny
Thanks guys,
Johnny
Johnny
They'll still be drawn to the car cause of the smell of their presence and the fact that a little used or infrequently used car represents a nice mouse house in or out of a garage.
If mice have been at the car you have to fix the damage, clean the car up and find a way to even though the mice will still be attracted -- initially -- to the car discouraging the mice from doing anything more than maybe kicking the tires.
Sincerely,
Macster.
I don't know if the mice have been in the car, I have just read a few posts about it happening.
The car is a daily driver as well. I put the hard top on in the winter and rip around town in it.
I will post if I find any evidence of mice. I went through the engine compartment last night with a high powered flashlight and a dental mirror, and there have been no mice there, it is spotless. I will look in the front around the gas tank next.
Johnny
Johnny
Johnny
Johnny
If car parked in garage and mice sign spotted around the garage almost certainly mice are in the car.
If garage clear of mice sign, car is likely clear as well.
The mice will nest in a car but they have to forage for food and water outside of the car.
If car parked outside or in an area where mice sign hard to spot...you might want to put a couple of mouse traps in the car baited with a tiny dab of peanut butter.
Then check the traps every other day or so. Just glance at traps. Don't make a big fuss around the car.
If you catch a mouse chances are there is another. A danger is if you catch momma mouse and she has babies they'll starve and die in the car which stinks up the car when it gets warm again.
If you catch a mouse in the car then you need to be very thorough and inspect the car for any signs of a nest.
Look under car on top of underbody or engine panels for any signs of nest trash. The panels should be clear of anything. If anything on panels....
Sincerely,
Macster.
The EPA vapor leak test is run ever time you turn the key to the on position. So, any open lines, seals, or valves would cause a fault.
