Sirius
What is the best way to implement Sirius in the 996? I have a 40th Anniversary with Navi.
I do not want to use FM Modulation as I am concerned about quality of sound.
I have an iPhone and heard that there is a new setup where you can use your iPhone to control stations.
Ideas?
Ideas?
If you have an iPhone then you can use the Sirius/XM iPhone App to stream music (using you data plan). I don't know how well that will work though on a moving car since AT&T's 3G is already pretty spotty as it is.
Super Moderator
Use the Dension with the iPhone app or I am pretty sure the Dension has a line in that you could hook a Satellite receiver into but you would not be able to control it through the factory radio.
I went with an aftermarket Double Din Nav w/XM but I can understand you wanting to keep it stock.
The Sirius/XM app works great on my Blackberry but you would be dependent on the Cell network.
The other great thing about SkyDock is that it is NOT set to a specific iPhone...your subscription is stored in the dock so you can move the dock from car to car and if you have another iphone you can also use. For example, my wife has the app on her phone as well and can use my skydock in her car with her phone!
I do have the 6 disc CD changer. Would I have to lose that functionality?
Currently my car has the CD holder/organizer on the top and A/C controls on the bottom. Removing the top one would be great.
If you have the CDR-220 (stock on older 996's) you can get an adapter from Becker which gives you an rca input on the back of the unit. You can plug in whatever you want, XM/Sirius, Ipod, etc. and use the AUX function. I do think that you lose the 6 CD changer when you do that, mine didn't have it.
