996 Forum 1999-2005
When to replace the clutch?
Old 11-03-2009, 11:35 AM
Orient Express
Orient Express's Avatar
My last clutch lasted 150K miles, and the current clutch has 65K miles on it with 60% of the lining left.
My recommendation to those that get lesser use from their clutch is to review their clutch engagement/disengagement practices.
Old 11-03-2009, 12:13 PM
DCP
DCP's Avatar
Originally Posted by smackboy1
After driving a 997 it's kind of bummer to get back into a 996 even if there is nothing wrong with the clutch.
I could not disagree more. I helped a good friend buy a new base 997 a while back. I drove it a fair amount. The difference was not noticeable at all. Meanwhile, he sold the 997 because he couldn't deal with it depreciating while I still have my 996.
Old 11-03-2009, 03:55 PM
Malakas
Malakas's Avatar
Ok how about the clutch fluid?
How often do u guys flush that? It's in the same system as the brakes no?
Old 11-03-2009, 05:19 PM
peavynation
peavynation's Avatar
Flush the clutch at the same time as the brake; yes, it's the same reservoir for both. Loren has an excellent DIY for all of it on RennTech.
Old 11-03-2009, 05:21 PM
yasuro
yasuro's Avatar
i don't know for sure, but suspect they are. when i flushed my brake fluid, i had burped the clutch. i don't know if burping helped, but my clutch creak went away as well.
Old 11-03-2009, 05:45 PM
Malakas
Malakas's Avatar
Just a little follow up - I had a very reputable Porsche tech drive the car. Said the clutch felt like new!!
Old 11-03-2009, 11:50 PM
goliver
goliver's Avatar
Everyone's different in clutch usage. I would wait to do a clutch job personally until it fails the 6th gear roll on test for you. Mileage doesn't mean much if you are all highway. A 99% driven city car will need a clutch way sooner than a 99% highway driven car all things being equal. That being said, some people are harder on clutches than others. My car needed a clutch when I bought it and I drove it over 900 miles home. Main risk is with gnarly slipping you can cook the flywheel surface. If it slips, back off until it hooks up and prepare for a clutch job. By the way, these cars are among the easiest cars on the planet to change a clutch on. If you even have a slight inclination to turn your own wrenches give it a whack. You'll be glad you did.
Quick Reply: When to replace the clutch?
