996 Forum 1999-2005
Check engine Code 456
Old Oct 31, 2009 | 05:02 PM
roadsession's Avatar
roadsession
Default Check engine Code 456
Just got a code 456 (read on an autozone scanner)
it said "code 0456 Very small evaporative systems leak"
I assume that is a loose gas cap or faulty gas cap?
Cleared the code - hope it stays that way ....:-|
Old Nov 1, 2009 | 11:07 AM
C4CRNA's Avatar
C4CRNA
Did you tighten the cap? It should click about 5 times. check it for damage to threads or gasket.
Old Nov 1, 2009 | 01:09 PM
M3 Defector's Avatar
M3 Defector
And be sure you have the new cap that comes with the recall.
Old Nov 1, 2009 | 01:55 PM
roadsession
ok what recall and what new cap! Sorry for the nube question...
Old Nov 1, 2009 | 01:59 PM
roadsession
Ok just did a search. I will check the part number to see if it's the older one
Old Nov 2, 2009 | 10:33 AM
roadsession
If it is a recall, can I just bring to the dealer to get it replaced? (BTW checked underside of the cap. That rubber seal is all cracked. )
Old May 4, 2019 | 09:42 PM
john981's Avatar
john981
I am reactivating this thread. I had some time ago a CEL and it showed P0456 very small evap leak. My indy cleared the CEL and I bought a new gas cap and I drove the car now for 250 miles, everything so far ok. Today I hooked up my icarsoft and in the obd section it showed again the code p0456 but there was no CEL. I turned off the car and turned it on again, ran the scan and the code was gone???? Any idea what it could be? My car is out of warranty but I still have the emission warranty in california, was wondering if it would make sense to have it checked at the dealership. Any advise would be appreciated.
