996 Forum 1999-2005
Now where's that manual... top is stuck.
Old 10-02-2009, 01:41 PM
wross996tt
wross996tt's Avatar
I do suggest getting codes read first. Calibration requires PST2 or PIWIS. It is possible the SmartTop came loose, so reinstalling it might help...you will probable need to do a soft reset after re-install (battery disconnect). So here are the other possibilities:
hydraulic fluid
control unit (or not)
latching mechanism (I doubt it)
other miscellaneous post with lots of links....from yours truly
The last thing I remember is can you observe whether the side flaps move?
Old 10-02-2009, 03:32 PM
PJorgen
PJorgen's Avatar
I once locked my keys in the car with the top down! Man was that dumb, and then it rained!
Old 10-02-2009, 03:51 PM
Tippy
Tippy's Avatar
Reminds me of an Aggie joke. Texas A&M University here in Tejas gets a bad rap for dumb jokes.
Here's one:
Why did the Aggie drown in the bed of a pick-up truck when it went into the Ocean?
He couldn't get the tailgate open.
Sorry......that was really bad.
Old 10-02-2009, 03:59 PM
wross996tt
wross996tt's Avatar
jeez riad...your friends are really helpful...LOL
Old 10-02-2009, 04:18 PM
Tippy
Tippy's Avatar
It's dirty Riad. Gotta go to OT to understand....
Old 10-02-2009, 08:51 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Rob, my guess is low hydraulic fluid.
To keep the Texas A&M Aggie jokes going:
Why are there zero suicides at A&M?
You can't kill yourself jumping out of a basement window!
Old 10-02-2009, 10:47 PM
mglobe
The Penguin King
mglobe's Avatar
How many Aggie jokes are there in total?
Two, the rest are all true stories.
Old 10-03-2009, 01:49 AM
ivangene
Parts Specialist
ivangene's Avatar
I heard Texas A&M was where the toothbrush was invented
anywhere else and they would have at least named it a TEETH brush
HEE HAW
Old 10-03-2009, 02:49 AM
Rob in WA
Cap'n Insane the Engorged
Rob in WA's Avatar
Too many dirty Riads will make your thing flaccid.
Old 10-03-2009, 06:49 AM
Gaspasser19
Gaspasser19's Avatar
Riad,
I've had my top act up when the Smart top module worked its way loose. I think you should start by checking that. I made a point of cinching the velcro strap down really tight and it seems to have solved the problem.
Old 10-03-2009, 10:51 AM
Tippy
Tippy's Avatar
New one I never heard.
I cant wait to tell my boss these who is an Aggie!
Old 10-03-2009, 09:33 PM
Riad
Chandler!
Riad's Avatar
Well the top seems to have worked itself out. Works fine now.
The one thing I did notice is when the rear deck lid goes up and back there's a rubber seal on the bottom, it seems I lost two little clips that keep the rubber on. It may have jammed at one point when closing.
So after not being able to get it up, it finally seems like it's a rubber problem.
Ugh, I need to get out more.
Old 10-03-2009, 09:39 PM
gota911
gota911's Avatar
Damn Rob, I don't have to use clips to keep my rubbers in place! My condolences to your wife!
Old 10-03-2009, 09:54 PM
Riad
Chandler!
Riad's Avatar
The clips are needed because the rubber is around 10' long.
And there are many other reasons for you to give condolences to my wife.
Old 10-03-2009, 10:34 PM
AmirShaikh
AmirShaikh's Avatar
Weird...
If you manually lifted the clamshell, and it didn't go back down by itself....
1) make sure the manual crank you used...screw need to be all the way out (nearly)..if not the clamshell doesn't move.
2) Keep an eye on the clamshell motor..it's directly attached to where you did the manual crank.
The hydraulic fluid only affects the actual top moving up and down and not he clamshell.
Glad it worked out though .
Quick Reply: Now where's that manual... top is stuck.
