How To Jack up a P-car
#46
Poseur
Ok guys, this seems to be a common question, and there doesn't seem to be any threads (that I could find) with concise information about how to properly jack up a 996/997.
We all know that if you jack from the rear jack-point (in front of the rear wheel), that whole side of the car will lift.
This enables a stand to be put under the front jack-point (behind the front wheel).
Do that to the other side and you have the fronts up.
Is this accepted as the "best" way for the fronts?
Rear:
Method 1: Jack up from the rear cross member if you have a low-pro jack.
Where is this? Can someone post a picture?
Then you can put stands under the rear jack-points.
Method 2 (not recommended?): Jack up from the engine, at the cast-in boss right behind the oil pan. (I found a picture of that). Then put stands under the rear jack-points.
How do you all recommend doing this safely for the person AND the car?
Rear:
https://rennlist.com/forums/997-foru...-securely.html
#47
LOL! But 128 are for beginners. the 256 Crayola box is the Honey Money!! ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Philooo: I take my used oil to local parts store, and always to the place I actually bought the oil; I feel that's only fair.
#49
This is a neat idea. Is this a do-it-yourself modification or does it require machine work and welding. I'm asking because if you pay to modify an Esco jack stand at a machine shop, couldn't you just about buy those Jackpoint stands they talk about on the forum? Don't the Jackpoints have a pin that goes up into the chassis too? Anyone know what it costs to have those changes made if you don't know a shop that will do you a favor?
#50
Former Vendor
Yes, the jackpoint jackstand caps to have a pin in the cap that will fit into the Porsche pin hole.
#51
Former Vendor
#52
I just checked out the Jackpoint site and their solution looks pretty clever, but over $300 each.
http://www.jackpointjackstands.com/Home_It_Works.html
This is cheaper but just as effective.
http://www.youtube.com/watch?v=PDz19...eature=related
#53
Former Vendor
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
They start at $289 a pair (either low profile or universal caps)
We do have a RL discount (PM me for details) and we are working on creating a group buy as well in the next couple of weeks when more inventory arrives.
#54
$289/pair is great. I guess I misread your site. It looked like the black low-profile ones were $329 each (It shows Qty = 1).
#55
Former Vendor
So if you were to place an order for (1) pair of stands you would enter 1 in the qty box. We understand that this can be confusing so we are working on cleaning up the copy on the site to minimize confusion. $329/pair on the site.
#56
Yes, you are correct. Black low profile is in stock (only two pair left in inventory, it has not been decided it more gloss black will be made in the future, I guess you can call it a limited run for now)
#58
Any inputs on what to do with the hardtop if it is currently installed? I just got a cabriolet that did not come with an owner's manual thanks to the previous owner, he did mention I should loosen the front latch before attempting to jack up the car, which seems reasonable, I'm just wondering if there are any other precautions?
TIA
TIA
#60
Poseur
As you can readily see in these pics, I just leave the hardtop on whenever it happens to be on the car and I have to jack it up. Makes no difference.
