IMS bearing replacement
#47
FWIW, my rationale on some of the earlier questions was this: Every M96 engine is vulnerable because of the IMS design, and always will be regardless of what you do to 'fix' it. But the retrofit part is overbuilt to a degree that Porsche could never have afforded on a mass scale. I don't see it as eliminating the risk 100%, but I do see it as reducing it by many orders of magnitude, at roughly 10% of the cost of a new motor. Just speaking for me, that math made sense.
#48
Bruce,
So basically, if you are going in to replace a clutch, like a RMS replacement, it makes sense to do this? Obviously, the part is more expensive than a RMS seal...
#49
Bruce -- also good to see you again on the site.
Were you having other work done, so did this as part of a larger maintenance visit (e.g., doing a clutch, rms & bearing at once)? Or was this a specific, preemptive strike?
#50
IMHO, that would be an easy call. A large part of the labour is redundant. The incremental cost would be in the hundreds of dollars in that case.
#51
This was a 'preemptive strike'.
I love the car, and I've done a lot to it to make it 'mine'. There's nothing I want more that would even come close to justifying the loss if I sold it, and that includes a 997. So the game becomes one of how to make it last. As I said earlier, its value to me is measured in the miles ahead of it. So I'm a maintenance *****.
#52
Thanks.
Who or where in TO did yours? How much? (I'm in Mississauga)
#53
http://www.engineeredautomotive.com
Dave Tomassetti is the former Pfaff tech I mentioned. I can't say enough good about these guys. Total perfectionists. They have a black C2 in there right now getting the kit installed, actually.
#55
#56
Several of the independants here are imploring me to bypass the M96-engined cars and stick with a Turbo/GT3 because of these issues. Unfortunately I either lose practicality (GT3) and/or increase cost and age (both Turbo and GT3)
Wayne.
#59
How about any shops in northern California?
TIA.
TIA.
#60
Since many asked, the shop that did mine here in Southern California is Otto's in Venice. Daniel, the tech is great guy.
I have had my car serviced between them and Callas Rennsport in Torrance, so i'm sure Tony can also do this; Otto's was simply closer and I've been going to them recently. Both are perfectly great shops.
