996 Forum 1999-2005
996 C4S Brakes Feel
Old Aug 25, 2009 | 12:03 AM
keithfox's Avatar
keithfox
Question 996 C4S Brakes Feel
How should 996 C4S brakes feel ?
I recently got a low mileage 2004 C4S and the brakes feel mushy to me. I don't drive it a lot, as it is my wife's car.
I also have a low mileage (double the C4S) 1999 Boxster and the brakes feel much better to me. They start biting as soon as you press the pedal.
The C4S brakes do not start biting until you push the pedal quite far and before that they have this mushy feel.
Now I know the C4S has the 996 Turbos's brakes, so they should be fantastic.
Is there something wrong or is this normal ?
Brake fluid change ? Replace brake lines ?
Old Aug 25, 2009 | 12:10 AM
ivangene's Avatar
ivangene
Parts Specialist
air in the lines / or old fluid with condensation of water particulates....
flush the brake lines IMO - they should not feel mushy at all -
where are you located - ?
onefastviking's Avatar
onefastviking
Turbo brakes are assisted and have a mushier feel.
Old Aug 25, 2009 | 12:13 AM
ArneeA's Avatar
ArneeA
try flushing the brake fluid AND clutch fluid.
Old Aug 25, 2009 | 07:01 AM
Marlon's Avatar
Marlon
My 99' C4 Tip has the EXACT problem - bled twice with 22 psi - no change. Appointment with indy tomorrow at 0900 - will report results.
Old Aug 25, 2009 | 09:10 AM
keithfox's Avatar
keithfox
Thanks for responses. Curious to see what Marlon finds out but your car is a c4 not c4s and the c4s brakes are from the turbo as onefastviking pointed out so it might be different. Ivanegene - I'm in Toronto and there are some very good independent garages here. Arnee - tip, so no clutch. Thanks all.
Old Aug 25, 2009 | 09:15 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
I haven't noticed this issue on my C4S. The brakes feel quite crisp and responsive.
Old Aug 25, 2009 | 09:20 AM
SH || NC's Avatar
SH || NC
Originally Posted by keithfox
I recently got a low mileage 2004 C4S and the brakes feel mushy to me. I don't drive it a lot, as it is my wife's car…. Brake fluid change?
Do you know when the last brake service was performed? Should be every 2 years per Porsche. If not, absolutely do the fluid flush. If the pads are low, do the whole service. GL
Old Aug 25, 2009 | 01:08 PM
jyoteen's Avatar
jyoteen
get a brake fluid flush done, and see if it that cures it (the flush should be done w/ the PST2 at the dealer as it'll replace all the fluid).
if it still feels mushy, maybe it's the master cylinder seal leaking just a touch.
Other issues could be a very, very slight leak of fluid (from maybe a caliper bleeder nipple...do you have to top off the brake fluid?). Secondary options are to replace the brake rubber hoses that go to the caliper, and finally, the actual brake pad compound.
Old Aug 25, 2009 | 01:23 PM
Torontoworker's Avatar
Torontoworker
Speaking about brakes: what is the line on Zimmerman instead of OEM rotors. There is about a 250 dollar difference between a set of four for a 996 c2. Doesn't seem like a huge savings for risk/gain. Has anyone tried this brand and if so - how did they feel and wear?
Old Aug 25, 2009 | 04:26 PM
medtech's Avatar
medtech
+1
Old Aug 25, 2009 | 05:19 PM
Marlon's Avatar
Marlon
If one could gently close the 4 rubbber brakes lines to the calipers, and then gently push the brake pedal - you should have a fairly firm pedal I would think? If the MC was bad, then would the pedal travel be 'too long'??? Or would that not be a valid troubleshooting technique?
Old Aug 25, 2009 | 09:48 PM
keithfox's Avatar
keithfox
I'll update the thread when I get this looked at. kf
Old Aug 25, 2009 | 10:03 PM
onefastviking
Zimmerman is an OEM supplier
Old Aug 25, 2009 | 10:05 PM
onefastviking
I'm lucky in that I get to drive many Porsches and it's most noticeable when you are very familiar with both cars. Not a huge difference, but there is a difference.
