Sunroof Fun
The sunroof I'm assuming is very similar to the power window. If it finds too much resistance, it will reverse direction or stop. Too much resistance comes from years of dirt build up, lubrication wearing away or even cables starting to get frayed or rough (again from lack of lube). I haven't looked yet, but if there is a diy on taking the sunroof apart to clean/lubricate, I think it would solve 99% of the problems...
BUT - if something "gummed up" a simple lube may not be the best solution, even if it works ok in the short run. Basically, you don't want to just put new lube over old lube if the old lube is filled with crud.
My sunroof track looked clean, but a bit dry and acted as if it was dragging. So a little motorcycle chain wax seemed like a good idea.
As with most things you grease up (axels, bearings, etc.), you want to make sure its clean first, then relubricate. For a motorcycle chain I'll clean it with WD40 and then use chain lube or wax lightly then wipe off any excess. You only want to use just as much lube as you really need, use too much and it just gets messy and collects dirt.
Note that I am not basing this on any particular information or expertise related to 996 sunroofs, or any sunroofs for that matter. I just applied common sense principles from motorcycle chains, which I clean and lubricate often, and applied them with some adjustments to my sunroof. And it seems to have worked.
...Rickker
It doesn't seem to have any friction what so ever except when closed and I push the button to lift it. It then attempts to move forward again and makes this pop noise when the back of the sunroof should just move up...but not forward again.
The other part of the problem is the switch is malfunctioning. I have to close completely before auto open works. Auto close doesn't work.
Any1 else have any feedback? Tomorrow my baby goes into the shop for it, hopefully it is something covered in my warranty. I have searched high and low and can't find anything on the internet that explains why I hear a pop noise when tilting the sunroof up (it tries to move forward again).
Also, taking her in to get the ignition replaced (covered on warranty).
So the result of the popping noise was that the sunroof needed to be recalibrated. After the calibration was done, it worked briefly, then the next day, back to the malfunction and popping sound.
The motor was replaced and this did the trick. Haven't had a problem for about a week now.
Yeah mine started acting up and making this popping noise, eventually had to replace the motor.
"This is done by holding down the rocker switch in the "close" position for ten seconds with the sunroof already closed. Under these conditions the sunroof control system will automatically switch to and run through the initialisation procedure."
This did work on my '99C4, but I still find I have to coax the system to do what I want it to. Anyway, good luck.
...Rickker
