electrical help needed!!
My problem is as I was putting everything back together (already had the power hooked back up to test the stereo) I was plugging back in the switches on the console next to the stereo - in my car is the central lock, and the cab top switch. Something must have tripped as I was putting in on the switches, as the windows went up and down, and the hood/trunk solinoids went crazy for a few seconds.
Unhooked the battery...put everything back together and now the windows don't work with the switch (but work when the cab top goes up/down) an the locks don't work - in addition the cars alarm won't engage - I get the double beep (its not the stereo since I unhooked that wire).
I put the Durametric through its paces and this is what I got when I scanned the "alarm" section...any ideas where to go from here??? Checked the fuses and everything seems fine.....Thanks,Will
larm
Current Fault Codes
61
Central locking limit position
Unlock not reached
Status: not present
Frequency counter: 1
47
Control locking synchronization
Status: not present
33
Interior sensor faulty
Status: not present
60
Lock not reached
Status: present
Frequency counter: 2
34
Status: present
42
Wrong key or wrong transponder
pill
Status: not present
18
Power window control
Status: not present
Frequency counter: 127
Copyright 2005-2006. Durametric Software Inc. All rights reserved.
Porsche, Cayenne, Boxster, Cayman, Turbo are registered trademarks of
Dr. Ing. h. c. F. Porsche AG.
Durametric Software is not affiliated with Porsche in any way.
