Battery dead, hood won't pop with jumper
#31
#32
Luggage compartment lid will not open with CHARGED battery.
My Porsche is 2009 911 Carrera S, had 40K service in July,did not try to open luggage compartment lid until two weeks ago and it will not open even though Porsche battery is fully charged! HELP! Does my car have an emergency cable under passenger wheel we'll? Does it require me to place car key in driver door lock?
Phil.
Phil.
#33
Have you tried the steps in the link above?
My Porsche is 2009 911 Carrera S, had 40K service in July,did not try to open luggage compartment lid until two weetks ago and it will not open even though Porsche battery is fully charged! HELP! Does my car have an emergency cable under passenger wheel we'll? Does it require me to place car key in driver door lock?
Phil.
Phil.
#34
Just a bump and a little help advice with 996 GT2s.
The hood would not open with the fuse box relay override (red stick) with jumper cables.
(I left the key in the ignition for a week. Ooops)
Luckily one can see the manual pull cable through the front rad cooling slits.
There is a hole in the black shroud ( right above the round hole for the tow hook eye) where you can just see the thin silver cable.
I used a metal fish tape with a hooked end ( a bent coat hook might work) to pull it out enough to grasp the cable and pull it with a needle nosed pliers.
Recharging the battery now.
I hope the immobiliser is not going to be problematic.
God I long for the old "analog" 911s.
#37
alternative solutions
i had a similar problem. The battery went kaput. giving the Red tab in the fuse box juice from another battery did not help either. I removed the wheel and the inside cowl trying to locate the steel cable to release the hood lock. For some reason i could not find it.
What i did alternatively was that i left the juice battery connected to the red tab in the fuse box with a earthing connected to the door hinge for about 30 minutes and retried. BINGO.. the hood open switch worked and i could manage to open the hood. Phew....
i have ordered a CTek Trickle charger to keep the battery in the pink of health.
#39
I have a 2002 c2, I SIMPLY CAN'T F$#@%^&ING BELIEVE an $80,000 car doesn't have a manual cable to release the front and rear trunk lids. Porsche, you put the BATTERY in the front trunk, then you design a front trunk that CANNOT be opened when THE BATTERY IS DEAD from inside the car with a simple pull of a lever like every single F$#@%^ING CAR EVER MADE SINCE THE BEGINNING OF TIME? Seriously, how dumb is that? I know there is a procedure that involves keys, and spare batteries, and fuses, and two priests, and animal sacrifice. Or I can take off a wheel and then a wheel liner to find a cable ....... to open the front truck? We are talking about the trunk right? WHERE THE F$#@%^ING BATTERY IS! You couldn't spend $12 total in parts on an $80,000 car to run a wire 8 feet? Rant over, that is all.
#40
The reason why is....
....it is lighter than running a steal cable and allows for a more "elegant" switch feel.
The Dodge Viper started this with electronic latch releases for its doors on the very first gen cars.
At least your Porsche didn't KILL you like this Corvette killed its owner due to the same design issue.
http://www.nydailynews.com/news/nati...icle-1.2253934
This is one reason why I like cars built before about 1995.
The latest BMWs and other such "High End" cars have all sorts of stupid nannies that don't allow you to open doors in gear and such.
#41
I just read the above article about the 2007 corvette and I sit here simply STUNNED that you cannot manually open the door of a 2007 corvette FROM INSIDE THE CAR (unless you happen to remember some secret procedure). I hope Chevrolet was sued and paid out hundreds of millions of dollars but of course that didn't happen.
#42
Received 1,091 Likes
This is sort of an old thread and common problem. Porsche did provide a manual release cable but made it difficult to use. If you have any 996 please take the advice of many and opportunity NOW to locate and relocate the trunk release cable behind the front bumper. It really amounts to a 10 minute job and can save hours, if not days, of frustration. If you have not done this..JUST DO IT NOW!
#43
#45
My car even has LoJack installed which has probably been more effective in protecting (and recovering) vehicles than alarm systems.
