996 Forum 1999-2005
Stuck horn
Old Jul 17, 2009 | 03:20 PM
Brian A.'s Avatar
Brian A.
Default Stuck horn
I'm sorting out some items in the new car. One issue is the horn does not work. So first thing I check is the fuse to see if its blown. Turns out the fuse is missing. This is easy I thought. I find a fuse, pop it in and presto, the horn works. Only problem is it works continually. Damn thing won't shut off. Any suggesting on where to start the troubleshooting? Horn or steering wheel?
TIA
Old Jul 17, 2009 | 03:44 PM
gota911's Avatar
gota911
Newbies Hospitality Director
Brian,
THe horn issue is a common problem. Check out this link on Renntech. If you are not a member there, it will pay dividends to become one.
996 Horn problem
Old Jul 17, 2009 | 04:18 PM
CosmosC4S's Avatar
CosmosC4S
I'm with Tim, I think the bushings are worn and the contacts are stuck in the closed position.
Previous owner probably didn't want to deal with resolving it, and so pulled out the fuse.
Good Luck!
Old Jul 17, 2009 | 09:59 PM
weatherthedecision's Avatar
weatherthedecision
As if the Porsche alone doesn't scream for attention by itself...now it is...literally =)
Get it fixed soon!
Old Jul 21, 2009 | 08:18 PM
Brian A.'s Avatar
Brian A.
Thanks for the link. The silicone solution worked like a champ!
